2000 k1200 fuel light staying on - BMW Luxury Touring Community
post #1 of 8 Old Jul 25th, 2012, 6:32 pm Thread Starter
I was wondering if anybody had the same problem of the low fuel light staying on. I can't seem to figure it out. Stays on even when fuel is full
whiteguy is offline
post #2 of 8 Old Jul 25th, 2012, 8:05 pm
Re: 2000 k1200 fuel light staying on
The brain may have "forgotten" the trip point and you need to reset it next time you know you have about 1 gallon left. If this does not fix it then the control unit has gone south.
  1. Empty the tank and fill it with 1 gallon (or your desired quantity).
  2. Make sure you have access to the diagnostic port of the Motorcycle and identify pin 3 and pin 4.
  3. Turn the ignition on.
  4. On the diagnostic port, short pin 3 (brown/black) and pin 4 (brown) for two seconds. (Make sure you have the CORRECT pins - you don't want to short Battery voltage to GROUND by mistake).
  5. The tank reserve light should flash quickly. When the flashing ends, the calibration is complete.
post #3 of 8 Old Jul 27th, 2012, 4:01 pm Thread Starter
Thanks for that tip I will try it. do both pins need to be grounded at the same time
whiteguy is offline
post #4 of 8 Old Jul 27th, 2012, 4:44 pm Thread Starter
It did everything you said it would do. It reset why the bike was running. I shut the key off and then turn it on again the light comes back on.
whiteguy is offline
post #5 of 8 Old Jul 27th, 2012, 5:32 pm Thread Starter
I am not so bright the reason the light came back on was there was not enough gas in the bike. Went and filled it up and the light went out. Thanks for the help. Now to go work on the abs
whiteguy is offline
post #6 of 8 Old Jul 27th, 2012, 5:34 pm
johnbaker15's Avatar
John was saying short them to one another not each to ground.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #7 of 8 Old Jul 27th, 2012, 6:03 pm
wa1200lt's Avatar
One of the 2 pins must be ground. If so, same difference. Signal to ground, ground to ground.
Loren
WAK1200LT
Loren
wa1200lt is offline
post #8 of 8 Old Jul 27th, 2012, 7:10 pm Thread Starter
what ever i did it worked. Thanks again
whiteguy is offline
K1200 Fuel Leak g_laskie K1200LT 39 Jun 11th, 2012 9:41 pm
2000 K1200 LT trunk latch pins? Doug_Gentry K1200LT 6 Mar 13th, 2006 9:08 am
