Ticking noise? any ideas? - BMW Luxury Touring Community
post #1 of 8 Old Mar 25th, 2006, 8:00 pm Thread Starter
I have a ticking noise coming from the left side of 2005 LT near my engine. It is quite noticable. Oil is new and full. Does any have any ideas on what this might be? Thanks.
BobbyDean is offline
post #2 of 8 Old Mar 25th, 2006, 8:20 pm
amarider's Avatar
If it's near the top of the engine it's probably the injectors - common.
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #3 of 8 Old Mar 25th, 2006, 8:23 pm
What speeds is it noticeable? Does it change with load/no load?
The injectors do click, but not all that noticeable.
It could be alternator drive gear backlash, some have it more than others. Does the ticking change if you turn the headlights on and off? If the noise changes based on alternator loading, then that is likely the noise, other than hearing it it is not a problem.
I had a ticking noise once in mine, it was broken exhaust header pipes on two cylinders. The welds inside the flanges broke, pulled the exhaust and welded them better than new.
post #4 of 8 Old Mar 26th, 2006, 8:22 am
How in the heck are you going to have the motor running with headlights off?
Leon
05 Blue LT
RideIt is offline
post #5 of 8 Old Mar 26th, 2006, 8:48 am
Leon
05 Blue LT
High beam, Leon!
post #6 of 8 Old Mar 26th, 2006, 9:41 am
Leon
05 Blue LT
I meant to say HIGH BEAM, forgot to qualify it.
post #7 of 8 Old Apr 6th, 2006, 10:51 am
zimbazi's Avatar
Bobby,
I have 2006 and that noise is getting louder on mine..When it is cold you can hear a louder clinging. Sounds like something in the exhaust? Going to visit th dealer tomorrow to get to the bottom of this. Will poast post an answer next week...I have Friday's off to ride !!
Jeff Goodwin
Austin, Texas
"Life is a coin.
You can spend it anyway you wish,
but you can only spend it once."
zimbazi is offline
post #8 of 8 Old Apr 17th, 2006, 8:27 am
zimbazi's Avatar
My noise was a bolt missing from that exhaust bracket..
check for lose or missing bolts.
Jeff Goodwin
Austin, Texas
"Life is a coin.
zimbazi is offline
Autocom noise problems DaveNH Intercom, CB, & 2-Way Radios 9 Mar 14th, 2006 7:11 pm
That noise that won't go away! blowingrock K1200LT 23 Feb 19th, 2006 9:00 pm
Any mounting ideas for Autocom/Gerbings leads? emsweeney K1200LT 13 Jan 10th, 2006 7:35 pm
Holiday Gift Ideas RVB1019 K1200LT 6 Nov 2nd, 2005 10:13 pm
CB antenna mount location ideas k12ltcdodrt Other R-Bike Discussion 0 Oct 17th, 2005 2:10 pm
