1ST gear what..is it me - BMW Luxury Touring Community
post #1 of 21 Old Mar 25th, 2006, 8:03 am Thread Starter
It seems when the girl is cool 1ST from neutal is a pain .I'm sure this cannot only be me....so what is the trick or do I just have to roll it and look like a fool w/temp tags??
Mike 05 K1200LT GOLD not lt yellow
shadowofshoe is offline
post #2 of 21 Old Mar 25th, 2006, 8:07 am
johnrehder's Avatar
Yep, they do that sometimes. I just fiddle with the clutch a bit a it goes. Pretty soon you won't even notice it once you find her sweet spot.
looking around for a possible replacement
2001 K1200 LTC Mauve (Hi-Way Star) may she rest in peace!
CCR'2001 Hotsprings, AR., Sante Fe, NM., Gatlinberg, TN.
Breckinridge, CO., Grand Teton Nat. Prk, WY.
Chateau Elan, GA., Tan-a-Tar-A missed it!
johnrehder is offline
post #3 of 21 Old Mar 25th, 2006, 8:18 am
BLBantz's Avatar
Put slight downward pressure on the shifter and slowly let out the clutch until it slips into first. Happens to all of us. Make sure you don't pound down on the shifter as this will cause the linkage to break.
Brian
Fanwood, NJ
2003 K1200LT Anthracite
BLBantz is offline
post #4 of 21 Old Mar 25th, 2006, 8:23 am
tarheel_rider's Avatar
What I've found in my extensive week long ownership of the LT, is that a small press forward usually lets it slip into first. The interesting thing is that my K75S required a small press backwards to slip it into first. Rolling it back doesn't do a thing for the LT and rolling it forward wouldn't do a thing for the K75S. I know, different generations, different trannys, etc, but each model has it's unique features and it just takes some trial and error to figure out what works. Good luck.
tarheel_rider is offline
post #5 of 21 Old Mar 25th, 2006, 8:24 am Thread Starter
Thanks guys been pounding it..won't continue but as a glitch it really can be embrarassing!!!
mike 05 K1200LT Gld
post #6 of 21 Old Mar 25th, 2006, 9:13 am
After some toe tapping you will become accustomed to it and no problem. Good Luck and enjoy.
Leon
05 Blue LT
RideIt is offline
post #7 of 21 Old Mar 25th, 2006, 9:24 am
If I pull the clutch lever all the way in I have the same problem as you. Try pulling it in only about a third of the way in. Its a LT thing
Brian Ley
WA State of mindless sheep
2007 K1200GT
2010 650GS
BMWOA 119892
sanjaun2 is offline
post #8 of 21 Old Mar 25th, 2006, 9:28 am
If
you let the clutch out a third or so a gentle push down on the shift lever will put it in every time.
parishollow is offline
post #9 of 21 Old Mar 25th, 2006, 10:07 am
Once you learn to use the clutch properly when doing it, you will not even think about it any more. You have to push down on the shifter, then let the clutch out just enough to move the gears a little, then it clicks in.
Another way: have the clutch all the way out in neutral, then time it so you pull the clutch back and push down on the shift lever just as the clutch lever gets all the way back, the gearing is still moving and it shifts easily.
This tranny is not like a car one, which has synronizers. It has shift "dogs" which line up with the next gear. If they are not aligned, it will not shift. It takes a little movement of the gearing to allow them to align.
post #10 of 21 Old Mar 25th, 2006, 10:25 am
Super Moderator
DavidTaylor's Avatar
Yep, that's normal. One trick is to put light pressure on the shifter and slowly engage the clutch a little, with an additional rocking of the bike front to back. this wil usually line things up quickly, engage 1st, and off you go.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #11 of 21 Old Mar 25th, 2006, 10:30 am
Motomadman's Avatar
Seems like every bike I have owned has been the same way. David is right about the transmission. Learned from riding Moto Guzzi's for 20 years to make sure I was in neutral before coming to a stop. It was very hard on the clutch release too sit at a light while holding the clutch in. Maybe there is a connection here on why the clutch slave cylinder goes out early because of holding it in for longer periods of time at stop lights. How many of you guys find neutral before coming to a stop??
Craig Hutchison
02 Pac Blue (Aka Blue Ox)
34 14 12.63 N
119 01 21.64 W
Why coast through Life when you can Corner it.
Motomadman is offline
post #12 of 21 Old Mar 25th, 2006, 10:36 am
That's a good idea if it does, indeed, result in less clutch wear but they taught us in the MSF BRC to keep the bike in first gear when stopped so you can execute an escape maneuver in case someone runs a red light (from behind you), or some other scenario.
What's the word, Mr. Shealey and other experts -- excessive clutch wear while holding it in at a light?
post #13 of 21 Old Mar 25th, 2006, 10:46 am
All manual shift vehicles do that. I don't like the method of slight pressure & letting the clutch out. What I have always done whether it is a truck or bike is let the clutch out in neutral, pull it back in & shift.
Big_E is offline
post #14 of 21 Old Mar 25th, 2006, 11:09 am
I always held the clutch in when stopped for lights etc. I did have two failed slave cylinders, the first was at 4500 miles though, so cannot relate that to anything other than faulty cylinder from the factory. The second one was at about 85,000 miles, and the failure mode was the release bearing in front of the slave cylinder piston tightened up and spun the piston in the cylinder. It is entirely possible that holding the clutch in when stopped could have contributed to that, causing the bearing to be spinning under load a lot over time.
Even if I thought that was the case though, I would just replace the cylinder at around 60K, and still keep the bike in gear when stopped. Just the way I rode, and liked the ability to move quick if needed.
The clutch itself does not suffer from that though, The one I replaced at 85,000 miles was only worn about 0.015" compared to the new disk, and the pressure plate and housing cover were still in excellent shape, no grooving or heat checking, so I just cleaned the brake fluid off them and re-installed everything with a new clutch disk.
post #15 of 21 Old Mar 25th, 2006, 11:18 am
gunny's Avatar
Pull the clutch lever in and immediatley tap the shifter. Don't wait for the gears to come to a stop.
gunny is offline
post #16 of 21 Old Mar 25th, 2006, 11:33 am
I just double clutch to get it in 1st. works every time.
dcwchfc is offline
post #17 of 21 Old Mar 25th, 2006, 11:58 am Thread Starter
Many good thoughts...the remaining in gear for a wayward cage is very tempting,I would hate to see it growing in the rear while stabbing @ the lever!! Many moronic drivers nowadays...
Mike 05 K1200LT gold
post #18 of 21 Old Mar 25th, 2006, 3:35 pm
Yes, exactly my point. There is a newer thread here that shows a cruiser dash camera's video of a biker getting nailed by a moron running a red light: http://home1.gte.net/res0ak9f/bike.htm
post #19 of 21 Old Mar 25th, 2006, 3:49 pm Thread Starter
Thanks all-the clutch release w/pressure on shifter works like a charm!!
Mike 05 K1200LT Gold?
post #20 of 21 Old Mar 25th, 2006, 4:49 pm
I haven't owned a bike yet that you didn't have a few of it's own idiosyncrasies. They come free of charge!
post #21 of 21 Old Mar 25th, 2006, 4:59 pm
Just like us riders.
Sticky Gear Selector markbreen K1200LT 4 May 30th, 2006 1:12 am
Where to find good touring gear SilverBuffalo Chit Chat 15 Apr 1st, 2006 7:37 am
Seal on the output gear box shaft Jerrym K1200LT 12 Mar 16th, 2006 8:49 am
LQQKing for riding gear that fits ErnieA Rider's Gear & Luggage 10 Jan 24th, 2006 11:05 pm
Pick a gear - any gear.... cpaine K1200LT 9 Nov 17th, 2005 8:13 am
