Fuel Filter Change Questions - BMW Luxury Touring Community
post #1 of 7 Old Mar 24th, 2006, 9:21 pm Thread Starter
The time has come to learn to change the fuel and air filters. My '99 doesn't have the quick disconnects on the tank yet, so I'd like to clarify the direction that the fuel flows when I install them (so's I don't get 'em McBackward).
I looked in the archives but didn't find anything definitive.
I've attached an image with my interpretation below. Have I got it right or not?
Thanks so much for your help
kflanigan is offline
post #2 of 7 Old Mar 25th, 2006, 1:11 am
Smile
Kevin,
Your picture shows a correct hook up of the fuel lines and the arrows show correct flow direction. The description shown isn't correct.
The fuel circuit is as follows: Inside the tank, fuel is pulled through a strainer and into the fuel pump. (pump is submerged.) From the pump to the filter directly above and down to the inner (closest to the center of the bike) hose stub on the pump assembly mounting plate (bottom of the fuel tank). Hose from there to the fuel rail (left / front/ top of the engine) that supplies the injectors. A regulator at the rear of the fuel rail (left / rear / top of the engine) returns unused fuel back to the tank via a hose across the rear of the engine and terminates on the outermost hose stub on the pump assembly mounting plate.
A couple of details. Make sure that the arrow on the filter points away from the pump (yeah, I know), carefully remove the crimp type clamps and replace with some decent screw type clamps torqued accordingly.
No real magic here.
Good Luck
Duane
Check the obvious first!
73 Z1 Kawi
and 7 long gone
Dman is offline
post #3 of 7 Old Mar 25th, 2006, 6:07 am
murray's Avatar
Lightbulb
Here is a picture of my 02. The outside line is the low pressure return. Note the T fitting this is where the fuel cell line is tied in Low pressure line. If you also go to the fuel rail the low pressure return line is the rear line.
Name:	Low Pressure Return Tie In.jpg
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #4 of 7 Old Mar 25th, 2006, 7:20 am
grifscoots's Avatar
Hey Kevin, you'll have to crimp off the lines at the tank before taking the hoses apart or there will be a nice flow of gas (you'll still get some from the engine side, not a lot, but some). You can either buy the tools (which aren't that expensive) or use small, locking pliers with coins in the jaws to keep from fubar-ing your hoses.
To be sure to put them together right: on one set of hoses leave the barbed connector in on one side, the other set of hoses, out. You're setting up a male, female thang here, but you won't get them confused.
A leetle warning: it's fun pulling them apart and you'll be shopping for some quick disconnects.
-=grif=-
Grok
grifscoots is offline
post #5 of 7 Old Mar 25th, 2006, 10:34 am
JATownsend's Avatar
Thumbs up Fuel Quick Disconnects
Actually, Grif himself posted this info a while back:
From www.mscdirect.com . Item #8808445 (2 each) and #88080486 (2 each). Be warned, they aren't cheap.
While you're at it, go to http://www.mcmaster.com/ and get you #9452K19. Industry standare -011 Size Bun-N. They are the o-rings that go on the quick disconnects. Package of 100 for $2.47.
Thanks again Grif!
J. Averill Townsend
Bloomfield Hills, MI
IBA# 24374
2002 K1200LTC - Silver
JATownsend is offline
post #6 of 7 Old Mar 25th, 2006, 6:32 pm Thread Starter
Smile Successful day in the garage!
Thanks all for the good advice. After watching Pauls DVD again. Everything went without a hitch, almost. I had purchased the plastic quick disconnects from Dennis Kirk in anticipation of this event, but on their arrival they looked "not too sturdy". I'll take Griffs advice and get the good ones. The only exciting part was that the left side rubber bushing that insulates the tank from the crankcase was completely missing! You could see where it had become wedged on the tank dust. It fell out somewhere along the way. A couple of days and I'll have a new one and be good as new!
Working on the bike is my therapy session. I get immense enjoyment from it and knowing that I can do basic service on the bike as well as any dealer with the exception of reading out the Moronic. This list is a great resource and enjoyment to participate in. It's been awhile since I've contributed anything to its support and I'm correcting that now. How about you?
post #7 of 7 Old Mar 25th, 2006, 7:46 pm
grifscoots's Avatar
I hear that.... I need lots of therapy.
-=grif=-
Grok
Fuel cell questions RMW K1200LT 18 Mar 22nd, 2006 7:33 am
New to the LT with some maint questions? jkkj71 K1200LT 8 Oct 28th, 2005 11:45 pm
fuel filter replacement sheldan2 K1200LT 2 Oct 7th, 2005 3:50 pm
Fuel filter replacement king K1200LT 7 Oct 6th, 2005 2:20 am
