Mirror....Mirror on the shake.... - BMW Luxury Touring Community
post #1 of 9 Old Mar 23rd, 2006, 2:31 pm Thread Starter
unleashd's Avatar
Well, Trouble with mirrors on the LT. Guess, the pop-off-drop-the-mirror-and-then-tether-it is a known situation. Mine is a bit different.
While installing the Hella FF50's, I had to remove the left mirror quite a number of times to test fit the lights. Now, I notice that there is a shake in the mirror. It seems to vibrate quite a bit while the engine is running - stopped or while riding. I was assuming that the mirror head might have gotten loose. Last night I popped off the mirror and noticed that the retainer clips in the mirrors seem to not be holding on tight to the 3 posts. This is causing a shake in the entire mirror body and is annoying while riding. For now, I put a piece of foam between the mirror and the mounting to keep the mirror from shaking.
Is there a way to tighten those clips?
Prakash Krishnamurthy
2004 R1150RT Titanium Grey
unleashd is offline
post #2 of 9 Old Mar 23rd, 2006, 2:58 pm
You can tweek them a little with needle nose pliers, But most people have better luck lubing the balls and clits I mean clips.
Brian Ley
WA State of mindless sheep
2007 K1200GT
2010 650GS
BMWOA 119892
sanjaun2 is offline
post #3 of 9 Old Mar 23rd, 2006, 3:44 pm
Look closely at the FRONT clip area, very likely that the plastic is broken on the front edge. That is a weak point in the plastic, and many of us have repaired that by drilling small holes on either side of the split, "lacing" it back up with strong thread or monofiliment then coating it with a thin layer of epoxy.
post #4 of 9 Old Mar 23rd, 2006, 8:55 pm
I believe you can buy a new inter plastic part if it is broken and you can buy new clips it you can't seem to get your old ones to work. If you search though the hall of wisdom you will find a tread that addresses a way to better attach the mirrors. I lost mine 3 time in a month and broke the tethers each time. I think I've got it right this time. RIDE SAFE
bikerkash is offline
post #5 of 9 Old Mar 23rd, 2006, 9:00 pm
I think I have a clip or two that I could send to you if needed. Just hollar.
post #6 of 9 Old Mar 23rd, 2006, 11:10 pm
Yes, the inner plastic body can be replaced for less than 50 dollars, at least for the chrome mirrors. I seem to recall an old post mentioning the painted mirrors are built differently.
mjordans2000 is offline
post #7 of 9 Old Mar 23rd, 2006, 11:48 pm Thread Starter
unleashd's Avatar
Sent ya a PM.
Thanks!!
unleashd is offline
post #8 of 9 Old Mar 23rd, 2006, 11:50 pm Thread Starter
unleashd's Avatar
Hmm....Its pretty late in the night here and well....don't put ideas into this feeble brain <G>
unleashd is offline
post #9 of 9 Old Mar 23rd, 2006, 11:51 pm Thread Starter
unleashd's Avatar
David, Those instructions went way over my head!! I am prolly the last person you would want messing with your bike I will surely take down those notes and look further into the possiblities. Thanks!!!
unleashd is offline
Dreaded front end shake RMW K1200LT 100 Aug 31st, 2007 11:13 pm
Wavering over an LT or a Wing--Help! ronjrieth K1200LT 60 Nov 22nd, 2005 6:05 pm
