2005 K1200LT Front Brake Pads - BMW Luxury Touring Community
post #1 of 5 Old May 25th, 2012, 3:55 pm Thread Starter
LJSMITH1's Avatar
Does anyone know why the OEM style BMW pads have multiple grooves cut in the pads?
I purchased and installed Carbone Lorraine pads which had a single groove down the center of each pad.
While the braking is fine and without squealing, I do hear a 'whine' or 'hum' similar to a decelerating turbine when I brake (actually its more like a 'zzzzzzzzz' sound). Its definitely coming from the front brakes. I think it has to do with the drilled front rotors and the single slot in the pads.
My theory is that the OEM pads have the multiple groves cut in them to address this very complaint. If not, why are the additional grooves there?
Thoughts? Comments?
2005 BMW K1200LT Blue
BMWMOA #124788
Predecessor:
1999 K1200LT (entered the BMW "organ donation program" on 6/2/11) 38,256 Miles
LJSMITH1 is offline
post #2 of 5 Old May 25th, 2012, 4:40 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: 2005 K1200LT Front Brake Pads
Cooling of the Pad/Rotor. That is why high performance rotors are drilled & slotted.
Stevie Shreeve
katnapinn is offline
post #3 of 5 Old May 25th, 2012, 4:41 pm
sperra's Avatar
I think that sound is cool , much better than squealing .
sperra is offline
post #4 of 5 Old May 25th, 2012, 7:30 pm Thread Starter
LJSMITH1's Avatar
That explains why the rotors are drilled. It has nothing to do with why the pads have slots on them.
The interesting thing is the grooves are not symmetrical on the length of the pad. This leads me to believe that they are designed to change the harmonics of the drilled holes in the rotor sliding by.
BMWMOA #124788
Predecessor:
LJSMITH1 is offline
post #5 of 5 Old Jun 1st, 2012, 9:36 pm
Scotty2's Avatar
Talking Re: 2005 K1200LT Front Brake Pads
The groove is there so people will ask questions!
Most rotors have groves and or holes to conquer the off gassing and cooling issues associated with braking. I have seen friction pads in various applications with this done for the same purpose.
However, in this case the groove in these pads is simply for you to know when to replace them again. When the grove is no longer visible its time to replace them.
Bonded pads I believe can run as low as 1/8th or 1/16th of an inch...you can use a drill as a gauge to compare the remainder of the pad beyond your groove to the steel backing. Then you can tell us all what you found.....
Scott
Scotty2
05 Metallic Graphite K1200LT
06 Metallic Graphite Bushtec Quantum Sport
09 Red R1200GSA
94 FXR Custom 113 c.i. S&S w/N20
LOLA 2006 = Love of Life Adventure
6 months, 3 weeks, 22,318 miles / Two up and still married
Scotty2 is offline
ebc FRONT brake pads edmann K1200LT 4 Feb 13th, 2012 6:56 pm
BMW Bulletin on Installation of Steel Brake Lines rdwalker Bike Talk 5 Feb 12th, 2011 11:25 pm
Rear brake pads too thick to fit? mbenn42 K1200LT 13 Mar 8th, 2010 9:47 pm
Front brake caliper problem -check all pads Waz K1200LT 0 Jun 10th, 2008 2:24 pm
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 10:37 am
