2000 LT Tune up--WOW - BMW Luxury Touring Community
post #1 of 2 Old May 7th, 2012, 11:27 am Thread Starter
I finally finished a re-do on my 2000 LT. New brake lines(Spiegler), new fuel filter and re-oil the K&N air filter. Valve check, new plugs, new front tire (BADLY cupped 'Stone after 4500 miles), and running wires for a soon to be installed CB. I also installed a new shifter linkage, and lubed the throttle cables. Lastly, I modded the wiring and installed a Ford solenoid to help the starter relay last a -while longer .(thanks JT !)
WOW !!! What a different machine I now have. It is much smoother, and pulls with excellent torque,as well as shifting like butter. No more missed upshifts into second now.
All I can say is it is amazing what a little TLC will do for these bikes. Lotta work, but well worth it.
One question. I have a Midland 820 CB ,and after reading and searching, I am still confused as to HOW to wire up the CB. I have power, but how do I intergrate into the intercom ??? I found the "Funk/CB" plug, as well as the two wire push to talk wires. Can I hook into the aux. plugs above the cassette, or do I need an adaptor cable to go into the multi-connector on the bike labeled "CB". ??????
signed, Confused and Clueless. ............
wolfflow is offline
post #2 of 2 Old May 7th, 2012, 8:15 pm
Re: 2000 LT Tune up--WOW
Now just get that K&N filter out of there and replace it with a proper paper element filter and your LT will live long and prosper!
Is a 2000 K1200LT a whole lot different then later models? Humbucker K1200LT 10 Jul 22nd, 2010 9:04 pm
03 Exhaust on a 2000 NRuest K1200LT 4 Oct 13th, 2009 12:02 pm
Which brand of intercom for 2000 KLT? rwlowry Intercom, CB, & 2-Way Radios 5 May 5th, 2009 5:17 pm
2000 K1200LT--should I buy? scout70 K1200LT 34 Nov 24th, 2007 10:58 am
2000 LT Brake fluid flush / change Doug_Gentry K1200LT 6 Nov 19th, 2006 5:02 pm
