2000 LT High Beam socket needed - BMW Luxury Touring Community
post #1 of 1 Old Apr 23rd, 2012, 12:05 pm Thread Starter
NRuest's Avatar
I had been running an HID low beam until the ballast died. Decided to replace the low beam and do the high beam this time. I found that the high beam socket wouldn't work since the cables and part of the ballast are attached to the bulb so I thought I could modify the socket to work. I cut slots in the black plastic socket to slip over the wires and drilled it out to snugly fit the extended bulb base. That part works great.
But not thinking clearly I also cut the metal socket that holds the bulb into the black base. That part didn't work out for me. So now I am looking for a new socket.
Does anyone have one for sale? It would be much quicker than ordering from the dealer. I would appreciate help on this screw up. Thanks
< - - - Norm Ruest - - - >
South Florida
2000 K1200 LTC Canyon Red
MOA# 145086
“Its unexplained, because they haven’t explained it. Maybe they could explain it, but they've tried and they can't, because it's unexplainable.” - Ruest
NRuest is offline
High Beam Ground Wire Attachment sglover005 K1200LT 2 Jul 3rd, 2011 7:46 pm
High beam, Silverstar or HID JCarver Lighting 6 Feb 17th, 2006 10:01 pm
Oops, I let out the magic smoke jkersh1 K1200LT 4 Oct 27th, 2005 8:36 pm
Piaa 910 relay High Beam trigger... Mike_the_Rat Lighting 5 Oct 17th, 2005 10:22 pm
Piaa 910 wire to High Beam... Mike_the_Rat K1200LT 1 Oct 8th, 2005 6:22 am
