07 LT; won't crank, no gear indicator - BMW Luxury Touring Community
post #1 of 5 Old Mar 18th, 2012, 11:30 am Thread Starter
CohesiveTechnology's Avatar
So I am waking up my bike after a long Winter's nap. When turning her on my first symptom is that the gear indicator is a simple black box - no gear shown.
I cycled the alarm three times using the fob, hearing the normal solenoid sounds and seeing the lights flashing as expected.
I then cycled the shifter through all gears and back.
I then disconnected the battery for about ten minutes, reinstalling afterwards and repeating the check above. Terminals are clean and sound.
The battery was on a BMW charger throughout the Winter.
I am fairly certain that this is logic related as no changes to gearing and no related maintenance was done that would present this kind of issue.
I seem to remember in the deepest recesses on my feeble mind reading about this very problem. I am looking for the fix now, but wonder if it is familiar to some?
Name:	Gear Indicator.jpg
David Falkenstein
Cohesive Technology - seamless is everything
P: (603) 283-7624
CohesiveTechnology is offline
post #2 of 5 Old Mar 18th, 2012, 11:39 am
zippy_gg's Avatar
Re: 07 LT; won't crank, no gear indicator
Do you by any chance have rodents entering your garage?
Some chewed up wires could be the issue.
Also I am assuming you have a fully charged battery, and not just relying on having the battery on a tender...
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 5 Old Mar 18th, 2012, 11:45 am
Is it in reverse?
edmann is offline
post #4 of 5 Old Mar 18th, 2012, 11:46 am Thread Starter
Belay my last. Pilot error.
Apparently it is important to connect all connectors prior to trying to start.
David Falkenstein
P: (603) 283-7624
post #5 of 5 Old Mar 18th, 2012, 2:36 pm
Very good! Next time just undo the single negative connector as it is easier to remember just one!!
jzeiler is online now
Gear indicator and clock not working pozo_izquierdo K1200LT 7 May 10th, 2010 9:28 pm
Gear indicator not correct ThaiBeemer RT Series 2 Feb 12th, 2010 2:18 am
R1200GS Gear indicator not working - help dholy GS Series 1 Apr 8th, 2009 7:21 pm
Shifting Problems / Gear Indicator Problems rwflier K1200LT 3 Jul 12th, 2008 8:27 pm
Shifting Problems / Gear Indicator Problems rwflier K1200LT 0 Jul 12th, 2008 1:09 am
