strange idle behavior - BMW Luxury Touring Community
post #1 of 12 Old Mar 19th, 2006, 5:56 pm Thread Starter
Question strange idle behavior
I have a 2000 K1200LT with about 30K miles. I just had the valve shims checked and it needed two exhaust valve shims but otherwise all in spec. Lately, I've noticed that after warming up, the idle "dances" between the normal idle speed (1K) and about 200 RMP above to 1200 RPM. If I don't touch the throttle, it revs up and down on it's own. It goes up to 1200 then falls back to 1000 and does this back and forth about 4 or 5 times before settling into a smooth 1000 RPM idle. It does not cause problems with performance but I was wondering if anybody could shed light on this behavior. Thank you. Lou Laguna
louatlvc is offline
post #2 of 12 Old Mar 19th, 2006, 6:49 pm
kip
similar behavior
my 99 does a similar thing....85,000 miles on it.....
sometimes when i pull up to a light it will rev higher and then settle back to 1000 and back and forth a few times....
ive observed it and wondered what was up with it but its never really caused any issues....
Kip
99 LT
97 Shadow 1100
Jefferson, Ga
kip is offline
post #3 of 12 Old Mar 19th, 2006, 7:11 pm
Vacuum leak. Check the tubes that slip onto the throttle bodies, excellent chance one of them is off. Probably nocked off when the valve work was done, or taken off and not put back properly.
post #4 of 12 Old Mar 19th, 2006, 7:13 pm
I 'second' the vacuum leak theory.
post #5 of 12 Old Mar 19th, 2006, 8:02 pm
If it doesn't stop after 30 seconds and continually does it then yes a vacuum leak but if it stops after a bit then its the computer controlling the idle while its cold..............regards Pete
petepeterson is offline
post #6 of 12 Old Mar 20th, 2006, 2:31 am
It could very well be a vacuum leak, as previously suggested. However, if the behavior does not continue, check the battery.
If the battery charge is low, the LT will compensate by raising the idle and you may notice the idle fluctuate in a similar way.
Stefan
stefan is offline
post #7 of 12 Old Mar 20th, 2006, 10:13 am
ratorino2004's Avatar
Did I hear anyone say vaccum leak?? Happend to mine within the first 300 miles. Hose of one of the throtle bodies....
Rich in Florida
ratorino2004 is offline
post #8 of 12 Old Mar 20th, 2006, 12:16 pm
grifscoots's Avatar
That's why you need to do a canisterectomy, take off all those hoses, rollover valve and plug them darlin's up.
-=grif=-
Grok
grifscoots is offline
post #9 of 12 Old Mar 20th, 2006, 12:34 pm
Bayliner2052's Avatar
Two years ago my 2000 did this, everyone said vac leak, even my dealer. Stripped her down and found none. I cleaned the battery connections and retightened them... all was and still is good in the world.
PS last year I needed a new battery, old one was 3 years old. Went with a cheap battery from WallyWorld, figured I could go thur 2 or 3 and still be $ ahead. I usually ride year round, but this year fog and ice kept me off the roads for 2 months! No battery tender and the battery got weak but still started on 2 revolution.
Vince Weidig
2000 LT - LandyachT
2005 Ural Patrol
2003 Artic Cat ATV - Horse
Bayliner Cutty Cabin - Anytime
Airstream B190 -
Bayliner2052 is offline
post #10 of 12 Old Mar 20th, 2006, 3:48 pm Thread Starter
Smile Many thanks!
Thanks so much for the great comments on vacuum and battery. I will check these out. I've had older airheads for years (still have them) and was worried that the new technology would be prohibitive as I've always enjoyed wrenching myself. I've found that the new bikes are intimidating to work on but this web site makes it far less so. Thanks again! Lou Laguna
louatlvc is offline
post #11 of 12 Old Mar 20th, 2006, 11:38 pm
You should be able to find fellow riders in your area to guide through basic maint and repairs. Check out the regional forum for your area. Also, if you fill out your profile a rider in your area may well speak up and offer a hand.
mjordans2000 is offline
post #12 of 12 Old Mar 10th, 2007, 3:27 pm
Labman's Avatar
Floating idle
Ok, so I've been searching and reading throughout the site about "rough" idle culprits on my 03 K1200LT. I just turned over 14K, and it received the 12K service when I bought it last year with 11K on it. Anyway, i'm in Georgia and just started to notice a strong gas smell on first start of the day, and then now a "floating" idle. The tach waivers between 1000 and 1300 at idle. I did suspect my battery getting old and lathargic two months ago when we had 25 degree nights. I ride daily, and when the temps got that low I was seeing a little "slow" turn-over. I bought a gel battery tender which indicated that I had a less than desiravle charge. So with all that, which rabbit hole to go down comrades?? #1-Throw down $7each for some NGK Iridium DCPR7EIX plugs for the optimal burn? #2 Pop the tupperware and search for the elusive disconnected vaccum line? #3 Canisterectomy? #4 Throw down for a new battery? (after all it is 3+ years old) #5 Shut the [email protected]*#-up and keep on riding!!
Anyway, I really appreciate input on my quest for I enjoy the LT greatly because it is truely awesome!! You can't slap the grin off my face after taching this thing out in just the first two gears!! Oh my, there are three more to go . . . .
KJ
03 K1200LT
97 Royal Star
79 XS1100
85 XS850
72 Norton 850
72 RD250
Labman is offline
Idle Drops on Deceleration Dochatley K1200LT 3 Mar 13th, 2006 3:49 pm
Strange Cruise Cable Question Dochatley K1200LT 4 Mar 1st, 2006 10:38 am
Olympic medals, strange origins of people dshealey Chit Chat 6 Feb 15th, 2006 7:31 pm
Strange things going on Joey K1200LT 7 Feb 14th, 2006 6:14 pm
Bike can't idle after pulling out radio remote plonk K1200LT 4 Oct 28th, 2005 9:16 am
