06 Proud Owner - BMW Luxury Touring Community
post #1 of 5 Old Mar 19th, 2006, 11:51 am Thread Starter
dsidler's Avatar
Smile 06 Proud Owner
Couple questions for the experts here.
#1 Can I replace the stop light bulbs with tailblazers without any problems? The tech at the dealer said I probably should not... something about the system check on startup. I can't see why it should be a problem but what do I know?
#2 Can I run trailer lights if I use an isolator? Again, the tech said I probably should not, possible overloading the wiring harness and toasting it. I would think the fuse would go first.
I would appreciate anyones advice and/or experience. Thanks.
dsidler is offline
post #2 of 5 Old Mar 19th, 2006, 12:00 pm
JATownsend's Avatar
Hello again Don,
1. I believe you CAN use Trailblazers or LEDs in the OUTBOARD tail lights. It is the center light that is tried into the system check.
2. I do not believe the 'basic' wiring system on the '06 is materially different than the '02s. It is NOT a CanBus system and you should be able to tie in directly to the battery and other systems the same way. Certainly its worth a quick call to Bushtec, Hannigan or Dauntless.
I'm sure the Gurus will weight in on this one!
Enjoy the New Ride!
J. Averill Townsend
Bloomfield Hills, MI
IBA# 24374
2002 K1200LTC - Silver
JATownsend is offline
post #3 of 5 Old Mar 19th, 2006, 12:29 pm
TMH
TMH's Avatar
Congrats on your new bike!
Can't help on trailer lights. But I was at my dealer yesterday and they were having a sale on all accessories. I asked about the Tailblazer bulbs for replacing the stock brake light bulbs on my 2002. I was told that the Tailblazers were not nearly as good as the Brake! LED units. Check them out at http://www.homebody-design.com/catalog/brake/brake.html
I don't see the version for the K1200LT on their web site at the moment, but I read something a couple of weeks ago that "after years of development a unit was finally available for the K12LT."
This unit, at ~$200, is about double what the Tailblazers would cost, but I do have on on my GS, and they are nice, bright, well designed and easy to install. I will probably go that route for the LT as well.
Tom
2009 R1200GS-ADV
2005.5 KTM Adventure 950
TMH is offline
post #4 of 5 Old Mar 19th, 2006, 1:03 pm Thread Starter
dsidler's Avatar
Smile Tailblazers
Thanks, guys. I used tailblazers on the 02, and like the story about the deer whistle and never hitting a deer, I was never rear ended. I still cringe since reading about your rear ender, Averill. Anyway, shortly after I installed the tailblazers in the 02, a guy pulled up beside me at a light and asked "Are your stop lights supposed to blink like that?" When I replied "yes" he said "Well, they sure get your attention". So since I have been a firm believer in them.
Do you y'all remember the "cyberlite" from years ago. I had one on my '79 RT. Don't see anything about them anymore.
About the trailer lights, I had a Dauntless hitch and trailer wiring on the 02 and the only problem I had was the fuse for the tail lights evidently wasn't big enuf. After blowing it a couple times, I installed a switch in the trailer wiring so I could turn the trailer lights off, leaving just the stop and turn lights. Only pulled the trailer in the daytime anyway.
dsidler is offline
post #5 of 5 Old Mar 20th, 2006, 4:59 pm
#1 No you cannot use the tailblazers on the brake lites of '05 and '06 models. The voltage difference on draw will cause a brake fault and the power centerstand won't work and power lock problems will be encountered.
#2 Yes you will need a remote relay or will have all sorts of faults. Friend of mine burnt up his harness not using one and cost him $5000 to replace.
Do what you want, but be warned
Jon Bush
' 09 RT
"SAPHIRE"
bushj1 is offline
First ride of 660 miles & New Owner observations usmctpdog K1200LT 13 Mar 19th, 2006 1:35 pm
Yellow writing pad's owner? Dick South Central 4 Feb 2nd, 2006 9:40 pm
Trying to locate owner GLWBMW South East 0 Jan 17th, 2006 11:24 am
"Return to Ironhorse" Update New LT Owner BamaLT South East 9 Nov 13th, 2005 10:00 pm
G'day from a new LT owner big dog Australia, New Zealand, and AsiaPac 11 Nov 10th, 2005 9:35 pm
