Fuel filter hose clips - advice please - BMW Luxury Touring Community
post #1 of 5 Old Feb 19th, 2012, 4:28 am Thread Starter
K100Dennis's Avatar
Just replacing my fuel filter and noted that the original hose clips can be left in place and the filter pulled out of each hose end. The new filter seemed to push right back on with the original clips in place. Is this normal procedure (to leave the original clips as is) or are they replaced with screw type clips at the first filter change. Thanks in advance, Dennis
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #2 of 5 Old Feb 19th, 2012, 5:06 am
Mugszy's Avatar
Re: Fuel filter hose clips - advice please
Hello Dennis,
You must replace the originals with the fuel line specific screw clips. You do not want these connections to come off. The system is under sufficient pressure that can pop a lose connection off which would leave you stranded.
Mugz
BMWMOA - #45711
2006 K1200LT - Blue Baby
2003 R1150GS - Yellowbird
1981 R100CS - Sadly gone
1986 K100RS - In the past
Mugszy is offline
post #3 of 5 Old Feb 19th, 2012, 5:08 am Thread Starter
K100Dennis's Avatar
Thanks, I thought so. Best regards, Dennis
Dennis
1987 Yamaha TY250R
post #4 of 5 Old Feb 19th, 2012, 6:10 am
Enjoy The Ride
saddleman's Avatar
Make sure you use the smooth wall fuel injection style hose clamps only. The size is 5/16. Do not use the serrated type worm clamps.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is online now
post #5 of 5 Old Feb 19th, 2012, 10:29 am
Not having seen this specific situation, I can only speak in generalities: manufacturers can use spring clips because the hoses they use are new and supple and don't require a lot of tension to seal. Spring clips are great at that point because they're quick, reliable, and don't take any precision to install. Once a hose takes a 'set', it often requires more pressure to re-establish a seal. So you have two options: a hoseclamp which provides a stronger seal, or replacing the hoses, which let you continue to used spring clamps. One drawback with the hose clamps: you can apply enough pressure to deform or crack the thing being attached to.
One guess as to which is cheaper.
05 LT - Blue
03 VTX 1300s - fun while it lasted, sucked in the cold.
Rocketsled is offline
fuel filter substitute? NOGILLS2 K1200LT 5 Jun 29th, 2009 10:14 pm
Wix fuel filter 104strad K1200LT 7 Mar 14th, 2009 6:51 pm
Middle of Long Trip And Need Fuel System Advice! Mike_H K1200LT 22 Aug 18th, 2008 6:29 pm
Fuel filter change question the_rocketman K1200LT 2 Jan 2nd, 2008 7:14 pm
Advice on Fuel Quick Disconnects Tom_Becker K1200LT 16 Sep 12th, 2007 9:59 pm
