Ford starter solenoid - BMW Luxury Touring Community
post #1 of 11 Old Feb 15th, 2012, 6:51 pm Thread Starter
anyone ever installed a ford starter solenoid in the battery area using the relay starter lead to activate the solenoid which would feed power from the battery to the starter
just curious if anyone has already done it
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #2 of 11 Old Feb 15th, 2012, 7:27 pm
Re: Ford starter solenoid
Don't quote me, butt I don't think an LT has a solenoid. Just a relay, and it is located in the electronics box under the fuel tank. PITA to replace, so they say!!
post #3 of 11 Old Feb 15th, 2012, 7:42 pm Thread Starter
Thanks Dick, thinking about adding a solenoid in the battery area operated by the existing starter relay - fords use a solenoid mounted to the fender instead of being part of the starter motor - I actually received the new relay with the bike when I bought it but when I had the tank off doing filters decided to put it off, I like the idea of taking the start load off the relay
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #4 of 11 Old Feb 15th, 2012, 7:54 pm
Patric's Avatar
I did it on my old '86 K100. The relay stuck on my K bike, so I took the BMW relay apart & filed the points . Then I put the Ford relay in using the BMW relay to energize it. Ford has a few different starter relays, I can't remember.. but it was something about there ground.. you need to get one that will work for you.
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #5 of 11 Old Feb 15th, 2012, 7:57 pm
AlaskaFish's Avatar
Wink Re: Ford starter solenoid
quick search for the Ford starter solenoid turns up a couple of threads that may interest you:
http://www.bmwlt.com/forums/showthre...arter+solenoid
Maybe these will provide some enlightenment for your project. Let us know what you end up with.
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #6 of 11 Old Feb 15th, 2012, 8:00 pm
Palerider's Avatar
Jim and Cyndy
'03 Black..."Ol' Dollar"
TDMTT
Palerider is offline
post #7 of 11 Old Feb 15th, 2012, 9:02 pm Thread Starter
Thanks John - interesting info, I did do a search but did not see the first thread and was wondering about the interaction from the reverser
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #8 of 11 Old Feb 16th, 2012, 5:33 am
wolfstudios's Avatar
Been using a Ford relay now for about5 or 6 years. Best investment for $10.00 versus the $80.00 investment that BMW wanted for their updated relay.
Just remember to have a pilot relay to energize the starter relay because of the coil current draw is more than the reverser circuit can handle.
Have the existing BMW relay operate the Ford relay and your good to go.
Cheers
71 Triumph 650 - 30,000 miles
76 Suzuki GT750 - 40,000 miles
85 1200cc Suzuki Madura - 107,000 miles
86 1200cc Yamaha Venture - 60,000 miles
99 BMW K1200LT - 158,000 (Sold)
09 BMW K1200LT -41,399 miles (and counting)
wolfstudios is offline
post #9 of 11 Old Feb 16th, 2012, 12:05 pm
http://www.bmwlt.com/forums/showthread.php?t=9661
Good info here.
especially post 15,16,and 23.
wolfflow is offline
post #10 of 11 Old Feb 16th, 2012, 3:45 pm Thread Starter
Good info here.
Thanks - that is what I was thinking needed to be done, the wire from the relay contact is energising a lighter load with the relay instead of the starter
I was quite certain I wasn't the first person to think of doing this
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #11 of 11 Old Feb 29th, 2012, 4:58 pm Thread Starter
I installed the Ford solenoid bolting down to the preload adjuster point, 2 pics one with adjuster up and one down. I could not figure out how to attach pics so link to flickr
http://www.flickr.com/photos/[email protected]/6942331877
http://www.flickr.com/photos/[email protected]/6796218344
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
No head light, no start. Everything else is normal??now baffeled k2steve K1200LT 17 Aug 31st, 2011 7:38 am
Fried Starter Relay and Dead Battery btcarver K1200LT 6 Jan 11th, 2011 12:50 pm
Need help! Starter solenoid is stuck on 2000 K1200LT....Any suggestions? wildwestrider K1200LT 3 Jun 6th, 2009 3:12 pm
Help On Starter Solenoid wsilvers K1200LT 9 Feb 4th, 2006 9:50 am
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 2:33 pm
