Starter Trouble shooting 2000 KLT - BMW Luxury Touring Community
post #1 of 10 Old Feb 15th, 2012, 11:34 am Thread Starter
BigH501's Avatar
Angry Starter Trouble shooting 2000 KLT
Hello All,
I am trying to trouble shoot some starting issues that have cropped up on my 2000 K1200LT.
I am having trouble starting.
So far I took it in to Advance Auto to get the battery checked and the battery checks out good and the charging system checks out good.
Seems when the bike sites a few hours the starter wont turn over...
After checking the battery and it reading fine, push button no start. Sounds like it may be trying to turn a tiny bit but not actually moving the engine.
Tried putting a power pack on it to jump it and nothing.
I bump start the bike, and ride home and decide to try reverse which I very rarely use to see if the starter will work at all.
Put it in reverse and push the button and it works fine. Switch back out of reverse, shut bike off and try starting again, nothing ...?
Just trying to narrow down my issue before I spend money and time to try to fix my issue.
Any sugestions... ?
Thank you
BigH501 is offline
post #2 of 10 Old Feb 15th, 2012, 11:44 am
taylorjn's Avatar
Re: Starter Trouble shooting 2000 KLT
Check battery connections, including the ground?
Jim Taylor
Minneapolis
07 Black LT "Dancing Heart", 03 Quantum "Ice"
02 Black LTC "Raven" (RIP 8/26/06)
08 Can-Am Spyder (hers) (#731)
taylorjn is offline
post #3 of 10 Old Feb 15th, 2012, 1:10 pm Thread Starter
BigH501's Avatar
Battery connections appear to be good and tight. No corroision. I just installed this battery mid December.
I did not trace the wires coming off the battery to see if the other end is good...
BigH501 is offline
post #4 of 10 Old Feb 15th, 2012, 6:27 pm
The feed point to the starter is the single terminal block behind the battery. This ties the output of the starter relay and the reverser controller to the starter itself. This appears tight since you can reverse. The problem may lie with the relay itself. The headlight should cut off when you push the starter button (if the relay is working). So If that is not happening then either the start signal is not making it to the realy or the relay is not working. Try that and let us know.
post #5 of 10 Old Feb 15th, 2012, 7:28 pm
gbob's Avatar
Hello Big
There are several starter intrrlocks that could be the problem , when my 99LT did the same thing is turned out to be the reverse interlock micro switch on the reverse shift linkage , that switch actualy makes the 12V negitive leg for the start relay .
Bob G
gbob is offline
post #6 of 10 Old Feb 16th, 2012, 7:50 pm
I got to thinking you also may have a gummed up starter sprag clutch. If you are hearing what sounds like the starter motor wirring but not turning the engine over the sprag clutch is the culprit. It does not come into play when reversing and can be intermittent when it is gummed up.
post #7 of 10 Old Feb 17th, 2012, 8:11 am
deputy5211's Avatar
Correct me if I am wrong, but the starter is NOT supposed to work if selector is in Reverse.
Antony (Tripod)
Dallas' Northern Suburbs
and many, many others.
deputy5211 is offline
post #8 of 10 Old Feb 17th, 2012, 9:39 am Thread Starter
BigH501's Avatar
Thumbs up Re: Starter Trouble shooting 2000 KLT
OK I rechecked all the wires and one of the wires which appeared to be pretty tight did turn out to have a tiny bit of play in it when I tried to move it.
I tightened it extra tight and the bike started.
I am going to have to keep an eye on it for the next few days to see if I get consistent results.
I feel a little dumb for thinking I checked the connection to the battery properly the first time.
BigH501 is offline
post #9 of 10 Old Feb 17th, 2012, 4:51 pm
BecketMa's Avatar
That's how I learn to improve working on my LT.
Best from Tucson
BecketMa is offline
post #10 of 10 Old Feb 17th, 2012, 5:52 pm
Ok true if the engine is not already running and you have reverse selected it will not spin. But if the engine is running, that is the motor that moves the bike during reverse movement. It is running but at a reduced speed controlled by the reverser controller. So in a nut shell if you can reverse the bike then your starter motor is OK.
Glad you got it sorted out Harold.
K1200LT 2000, Starter motor won't shut off? Nmclay K1200LT 33 Oct 22nd, 2014 7:56 pm
Need help! Starter solenoid is stuck on 2000 K1200LT....Any suggestions? wildwestrider K1200LT 3 Jun 6th, 2009 3:12 pm
Help Trouble Shooting Dead Radio Lynn_Keen K1200LT 9 May 16th, 2009 1:29 pm
Electrical trouble shooting Michaeldale Batteries, Chargers, & Electrical 5 Oct 1st, 2008 6:45 pm
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 2:33 pm
