K1200LT windshield adjuster - used part availabilty - BMW Luxury Touring Community
 5Likes
  • 1 Post By RonKMiller
  • 1 Post By simoncharles
  • 1 Post By Mark65
  • 2 Post By gunny
post #1 of 35 Old Feb 12th, 2012, 11:16 am Thread Starter
Hello, first time writing into the forum. I own a 2000 K1200lt and had a little acident where I bonked my windshield on the side of my shop garage door frame. The result was a broken lower arm on the left side of the windshield adjuster. I've been searching for a used adjuster mechanism on the net and calling various salvage yards throughout the US. I have not had any luck, so I wanted to put a shout out for additional ideas or resources. Any help would be much appreciated!
chumdog is offline
post #2 of 35 Old Feb 12th, 2012, 11:26 am
sheldan2's Avatar
Re: K1200LT windshield adjuster - used part availabilty
Good luck, I am waiting for one as well. They are hard to come by. You could try get on the waiting list at beemer bone yard.
Courage doesn't always roar. Sometimes it is the quiet voice at the end of the day saying " I'll try again tomorrow".
sheldan2 is offline
post #3 of 35 Old Feb 12th, 2012, 12:16 pm
"Windshield pivot arm needed"
search for this thread
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #4 of 35 Old Feb 12th, 2012, 12:35 pm
casualemt's Avatar
I don't see any pivot arm part on the windshield that couldn't be fabricated out of a peice of aluminum (and painted flat black). Since you will have to take the old one off to replace it, I would seek out a metal fabricator, boat builder, or even a carpenter in your area, and get one made. If you have a few common tools in your garage, Aluminum for the most part can be machined using a lot of wood working tools. You probably could look for a boat builder in your area if you wanted a peice of aluminum big enough to make a part out of, from their scrap pile...Here is the link to Dick Largen's post about fabricating windshield parts from Lexan/plexiglass using a dremel tool etc...
http://www.bmwlt.com/forums/showthread.php?t=61223
Good Luck!
RICH CANNON
2000 K1200LT "a great ride"
1979 XS1100 (gone)
1986 VT500 Ascot (gone)
1972 Honda 500-4 (gone)
1961 Lambretta (way gone)
casualemt is offline
post #5 of 35 Old Feb 12th, 2012, 12:41 pm
I have a complete windshield motor assembly for sale, I just haven't posted it in the Classifieds forum yet. It came off an '09 LT, after a similar incident as you describe. You'll have to determine if it's compatible with your model year LT.
The right lifting arm is broken; it is OK otherwise.
Email me if you are interested. (prefer email over PM; my email address is available from my profile)
post #6 of 35 Old Feb 12th, 2012, 5:07 pm
sheldan2's Avatar
Thanks Howard, but I think I am in the same boat. The windshield goes up and down, but the one arm is definitely broken.
sheldan2 is offline
post #7 of 35 Old Feb 12th, 2012, 9:12 pm Thread Starter
Thanks, good luck finding one! I have requested notification from Beemer Boneyard when one is available.
chumdog is offline
post #8 of 35 Old Feb 12th, 2012, 9:17 pm Thread Starter
Thanks for the response. I'll check and see if the parts/years are compatable and get back to you ASAP. Thanks!!!
chumdog is offline
post #9 of 35 Old Feb 12th, 2012, 9:59 pm Thread Starter
Good Luck!
Thanks for the info! I may end up just fabricating my own out of aluminium. I thought if I could get an original part with relative ease I'd go that direction. As it turns out, that part is a little tough to come by since they break easily and replacements are in demand! BMW only sells the complete unit for a hefty fee - odd, they would probably sell a bunch of the arms if they offered them seperately!
chumdog is offline
post #10 of 35 Old Feb 14th, 2012, 11:32 am
copperstatetour's Avatar
Here is one I saw on Ebay, says it is usable as is. Ebay Adjust Bracket
copperstatetour is offline
post #11 of 35 Old Feb 14th, 2012, 1:54 pm
Right! It doesn't make sense to me, either. I needed only the right arm but had to buy the entire unit for $657.59 + tax.
post #12 of 35 Old Feb 16th, 2012, 7:26 am
KJN
KJN's Avatar
Might be worth a try...
http://phoenix.craigslist.org/evl/mcy/2832988244.html
http://phoenix.craigslist.org/evl/mcy/2804419071.html
If the link doesn't work, just look up BMW on the Phoenix craigslist motorcycle listings.
Good luck...
Kimble
Phoenix
KJN is offline
post #13 of 35 Old Sep 20th, 2017, 5:12 am
I am reviving an old thread about windshield pivot arms, in case anyone could give me some help.
I have been trying to remove the bit which is attached to the rod with a 8 mm bolt ( plus a clip which I donīt know what it does ) with no luck at all.
How can one remove this bolt without using too much brute force and risk damaging anything else ?.
Has anyone tried glueing or welding these two parts together with a succesfull result ?.
Thanks in advance for any suggestions offered.
ID:	133586   Click image for larger version
ID:	133594   Click image for larger version
simoncharles is offline
post #14 of 35 Old Sep 20th, 2017, 9:22 am
RonKMiller's Avatar
JB Weld and a couple of strong rubber bands are your friend. Coat each piece with a VERY thin coating - in this case less is more.
61774Rob likes this.
"Like Butt-ahh!"
RonKMiller is offline
post #15 of 35 Old Sep 20th, 2017, 12:03 pm
Thanks. This is quite interesting.
kbob12 likes this.
post #16 of 35 Old Sep 21st, 2017, 6:42 am
I have again tried to remove, with no luck, the 8 mm bolt that is, in theory, screwed into the hexagonal rod, as shown in photo # 1, which activates the up/down movement of the windshield.
Could somebody please confirm that it is possible to unscrew it from the rod, as removing the broken bit from same would make repairing the two parts a lot easier.
post #17 of 35 Old Sep 21st, 2017, 10:48 am
Your photo shows one of the 5 bolts that hold the adjuster to the frame (#2 and #5 and yes they should cone right out only 9 Nm on install). I do not see anything going into the hex shaft. The arm should slide off after you remove the clip but there is likely corrosion on there.
post #18 of 35 Old Sep 21st, 2017, 1:31 pm
Thanks John, but I meant the one at the end of the rod as shown in this diagram
post #19 of 35 Old Sep 21st, 2017, 1:35 pm
Maybe it isn't a bolt and what is holding the arm in place is the clip which I had removed.
Will check tomorrow and confirm.
Thanks.
post #20 of 35 Old Sep 21st, 2017, 2:54 pm
RonKMiller's Avatar
https://www.youtube.com/watch?v=XObmZIbHOzY
A pretty good comparison although his methodology is pretty crude. I'm not quite sure why he included the JB Weld "high heat" in the comparo, since it's designed for hot temperatures (2400F!) and perhaps cures differently when exposed to them.
I've used regular JB Weld to fix many "unfixable" parts over the years. The only drawback is that you really need to give it a solid 24 hours to cure, and like many epoxies a slight amount of compression seems to help as well. I always have some in my took kit. On a rough surface break like the cast piece it works REALLY good and is at least as strong as the original material.
"Like Butt-ahh!"
post #21 of 35 Old Sep 21st, 2017, 8:44 pm
Thanks.
That is a hex shaft the full length and the part should just slide of but it may take a bit of coaxing with some (if you can find it there) Tap Magic for aluminum. It is a threading lube that really works wonders on even galled aluminum parts.
post #22 of 35 Old Sep 23rd, 2017, 12:12 am
Mark65's Avatar
I finally found an assembly to replace my broken one, and bought it! It's only taken me about eight months or so to locate it, so not too bad, I guess. Just hope the 02 version works on an 06 bike, lol.
Mark
Mark(Big Poppa) and Julie(Fireball)
'06 K1200LT Magnesium Black "Stella"
Glendale, AZ
BMWMOA#206887
RA#44657
AMA#3647653
Let's Ride!
Mark65 is offline
post #23 of 35 Old Oct 23rd, 2017, 5:47 pm
vespacar's Avatar
If it doesn't fit, I'll buy it from you. If it does, let me know as I'll be able to fit an 06 and up one on mine. Thought the J-B weld is looking good. Now Ill just have to remove all those tie clips that are holding it together (hey when on the road you use what you have).
Cheers,
Tross
Mark
2002 K1200lt
2010 Piaggio MP3 500
1982 Lambretta GP225
vespacar is offline
post #24 of 35 Old Oct 23rd, 2017, 8:05 pm
Mark65's Avatar
Cheers,
Tross
It fit with no modifications. Buy the one you can get, they're all the same part, apparently.
Glendale, AZ
BMWMOA#206887
RA#44657
AMA#3647653
Let's Ride!
Mark65 is offline
post #25 of 35 Old Oct 24th, 2017, 4:22 pm
gunny's Avatar
Been there. Done that.
Ended up buying a new adjuster assembly for a few hundred dollars.
Still have the old one and if I ever need it, I'll apply some JB Weld and go.
That is some great stuff. Many many years ago had a Triumph 650 with 2 carburetors. One Friday evening, one side ran lean and burned a hole in the piston. Needed to be at work Monday morning 250 miles away and the only transportation I had was that Triumph. Took it apart, degreased the piston well, mixed up a batch of JB Weld and patched the piston. Put it back together Saturday evening, cleaned the trash out of the carburetor and fired it up Sunday morning. Said a prayer and hit the road. Got me to the new job nd back a few times. Ended up trading it from something, forget what but it held together.
Mark65 and kbob12 like this.
B D R
gunny is offline
post #26 of 35 Old Oct 24th, 2017, 7:48 pm
kbob12's Avatar
Amazing stuff! Years ago I sealed a crank in an engine block water jacket with JB Weld. Drained the block, ground the cracked area, filled it and waited overnight. Fired it up and ran it-no leaks! And, it held for years! It might be still running today...
Covina, CA
2000 K1200LTI Champagne
kbob12 is offline
post #27 of 35 Old Mar 29th, 2020, 7:36 pm
Reviving an old thread here but I must be the last guy to break one of these 'doglegs'. Had a Fabrication shop make a few for me. If anyone is interested I have 3 extra sets. Just need a bit of fitting such as filing to thickness on the windshield mount end and reaming holes to pin size. PM me if interested. Jim
Budman831 is offline
post #28 of 35 Old Mar 30th, 2020, 9:14 am
Send me the part number, I most likely have it .
globecom is offline
post #29 of 35 Old Apr 7th, 2020, 11:11 am
Hi
Did you ever get the remnants off the hex rod? I've got a new part but cant seem to remove the old one - circlip off and WD40 +++
DaveIves is offline
post #30 of 35 Old Apr 8th, 2020, 7:07 am
Originally Posted by DaveIves View Post
Hi
And done! Soaked overnight and gentle persuasion with hammer and flathead! Replacement on no problem. Than noticed top arm on other side out of locating holes! Expert (!) now, dismantled and reassembled. £25 for second hand arm from Motorworks and lots of patience, saving cost of £600+ new adjuster assembly. Thank you Forum!
Sent from my SM-N960F using Tapatalk
DaveIves is offline
post #31 of 35 Old Apr 8th, 2020, 7:10 am
For those who need a source (in UK) try
https://www.motorworks.co.uk/vlive/S...T=6&Q=FAA81430
DaveIves is offline
post #32 of 35 Old May 23rd, 2020, 8:57 am
Hanshi's Avatar
Hello Jim: Do you still have any of the replacement part for the lower windscreen adjuster on a BMW K1200LT. I am in dire need of one. Could you email me at : [email protected] or call at (610) 207-3972. Let me know cost and how you want payment if available.
My address is: 11 Club Lane, Reading, PA 19607
Thanking you in advance.
Hanshi
Reading, PA
Current Bikes:
2007 BMW K1200LT (Black)
2008 HD Electra Glide Ultra Classic (red)
HF Tag-Along Trailer
Past Bikes:
2004 BMW K1200GT (Grey-Green)
2004 Suzuki Intruder (Black)
Hanshi is offline
post #33 of 35 Old May 24th, 2020, 10:50 am
Boxhead's Avatar
I just did an adjuster repair. Fiberglass and epoxy combo with a washer.
ID:	157009   Click image for larger version
ID:	157011   Click image for larger version
Boxhead is offline
post #34 of 35 Old May 24th, 2020, 12:28 pm
james216's Avatar
$657.95?? OUCH!!
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #35 of 35 Old May 24th, 2020, 12:30 pm
I need a top adjuster arm if anyone has one spare?
peterj is offline
HI LO HID Installation on 99 K1200LT With Pics ! JPSpen Lighting 37 Jul 12th, 2008 11:44 pm
Speedbleeder part# for a 2001 K1200LT cjgonzo1 K1200LT 7 Mar 8th, 2006 10:47 pm
