No Set or Switch lights for CC - BMW Luxury Touring Community
post #1 of 3 Old Mar 16th, 2006, 3:59 pm Thread Starter
I can't find any info in the HOW about problems associated with Cruise Control not powering-up at all. I have no set light on cluster or red light at the Switch. Any possible points of electrical disconnect other than fuse I should check?
I don't recall what other systems are tied in with CC but I know it's not a fuse. My repair manual is useless.
Macker is offline
post #2 of 3 Old Mar 16th, 2006, 5:29 pm Thread Starter
There is a CC test procedure posted here somewhere.
The procedure involves Ignition Switching, Clutch switch, Brake Switch (Front & Rear) and Throttle as well as the Set and Resume switches.
I'll attempt to find it.
Found it HERE.
O.K., I think I get it.
I saw this...
This is the diagnostic function that uses the light to tell me why the light isn't coming on!?!
I trust you Dave!! I'll try it tonight.
Macker is offline
post #3 of 3 Old Mar 17th, 2006, 6:40 am
I had a similar problem. No light at the CC switch intermittently. It turned out to be the contacts in the switch. A new switch was $$$, so I got the cruise switch to turn on, and I just leave it on. No big deal to me. All cruise functions work (set, cancel, resume).
Tat_n_Telle is offline
Auxiliary Lights hschisler Lighting 55 Nov 29th, 2014 10:00 pm
PIAA 1100X mod - Daytime Running Lights Daza Lighting 7 Jul 10th, 2009 12:11 pm
Hella FF50 Driving Lights installed unleashd Lighting 22 Aug 21st, 2006 2:11 pm
Lights & Ezy Mount Brackets EzyMount Lighting 3 Feb 24th, 2006 5:04 pm
Oops, I let out the magic smoke jkersh1 K1200LT 4 Oct 27th, 2005 8:36 pm
