ABS, Good & Bad news - BMW Luxury Touring Community
post #1 of 24 Old Mar 15th, 2006, 12:18 pm Thread Starter
Unhappy ABS, Good & Bad news
Had the dealer reset the ABS on my '00 LT. Service manager said the Tech was able to accomplish the reset but the fault read a "recommendation to replace" the entire control unit.
Has Anyone been through this scenario and have the control unit last any measurable amount of time after a reset, considering the diagnostic unit's recommendation for replacement?
He mentioned that sometimes they go for thousands of miles and sometimes they go to the end of the block. He said I have a chance since he was able to reset. So far, I've got 30 miles...
Warranty is fresh up, so I guess I don't have a choice. $1200.00 for a new unit.
Macker is offline
post #2 of 24 Old Mar 15th, 2006, 12:28 pm
Cat Herder
andy's Avatar
Before I would cough up $1200 I'd give it a try. HOW did the ABS fault how up in the first place?
andy is offline
post #3 of 24 Old Mar 15th, 2006, 12:28 pm
Thumbs up
I got 150 miles before mine faulted again. You got a better price then me. It's about a half of days work to replace.
captainasty is offline
post #4 of 24 Old Mar 15th, 2006, 12:30 pm
Bouncer
eljeffe's Avatar
Yes, I went through this. The error that came up was some sort of "piston fault".
The first time they re-set it, it didn't re-occur until a year later. Then it was several months. Then it happened all the time. So you could have up to a year and a half of use out of it before it happens again.
__________________
El Jeffe
Plano, TX
'06 K1200GT Crystal Grey
'04 Sprint RS Caspian Blue
__________________
eljeffe is offline
post #5 of 24 Old Mar 15th, 2006, 12:41 pm
I had the same thing happen on my 2000 LT. When they reset ,it only lasted a few minutes. The previous owner didn't change the brake fluid for 4 years. That's why BMW says change every year. My dealer priced repair at $1700 plus $300-400 labor.
Badboy is offline
post #6 of 24 Old Mar 15th, 2006, 12:44 pm Thread Starter
Manager said it was probably just a coincidence...But I suspected It was caused when I put the bike in gear while on the center stand (Checking something out) throwing off the speed sensor. I thought this was the whole problem. Not my luck, I suppose.
I also replaced a low battery.
I'm going to call the warranty company, maybe I have until May! Can't remeber.
Macker is offline
post #7 of 24 Old Mar 15th, 2006, 12:46 pm
If you're just barely out of warranty and you have a good relationship with the dealer, maybe they will cut you a deal? Pay for parts but not labor, or pay 1/2 the total? Can't hurt to ask.
post #8 of 24 Old Mar 15th, 2006, 12:57 pm
Cat Herder
andy's Avatar
That is what I suspected. The ABS fault you describe is not really a fault per se. It is the computer complaining that the two wheels were turning at a rate that is incompatible. Same thing happened to me when I layed it down once. Dealer reset the ABS fault and it never came back.
DO NOT PUT IT IN GEAR WHILE ON THE CENTERSTAND. That will trigger an ABS fault every time.
andy is offline
post #9 of 24 Old Mar 15th, 2006, 2:00 pm
Zotter's Avatar
Several times this winter, while up on the center stand, I'd let 'er run at idle, in gear - to get the fluids spread around.
Likely not needed at all - but it felt good.
::knocks on wood:: so far, no faults here. Maybe cuz front wheel weren't turning at all? ABS test never went out.
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #10 of 24 Old Mar 15th, 2006, 2:21 pm Thread Starter
Hello Tate
Very well could be O.K. if @ Idle. Could be...problem happens if you go above 3-5mph on the speedo. Just a guess.
Could be you just have the luck I wish for!
Probably not a good idea as luck always seems to run out sooner before later.
Macker is offline
post #11 of 24 Old Mar 15th, 2006, 2:28 pm Thread Starter
Hey Andy,
I just thought to ask...Did you get the same "recommendation to replace??"
Could it be the computer just thinks the ABS unit is going bad?
This would give me encouragement and a little hope!
Macker is offline
post #12 of 24 Old Mar 15th, 2006, 2:34 pm
Cat Herder
andy's Avatar
Hey Andy,
No, back then I did not get a recommendation. When I had it in BMW of Denver was very curtious and they told me that the different speed on the front and rear wheel WILL cause a fault. And if you think about it: If the moronic 'sees' drastically different speeds on the front and the rear it HAS to believe that there is something wrong.
As I said: They cleared the fault code and it never happened again. (Because I didn't lay it down again )
andy is offline
post #13 of 24 Old Mar 15th, 2006, 3:04 pm
Beemerider's Avatar
Exactly what I did. Have a habit of starting bike, place in gear, ride away no feet when bumping it off the center stand. Was real good about not doing this on the LT but brain farted leaving work after a mid shift one morning and presto magico got the fault. Had dealer reset and rode it a considerable amount of time and distance w/o another occurrence before trading. Was the same piston fault Jeff mentioned.
Ride On!
Goodyear, AZ
"Yeah but its a warm heat!"
'13 SILVA K1600GTL
Beemerider is offline
post #14 of 24 Old Mar 15th, 2006, 6:02 pm
Question Am I just liucky, or what?
My experience is quite different than suggested here. I've been under the impression that if the ABS hasn't "set" that it will wait for the appropriate signals from the front and rear wheels before going into operating mode. If it isn't in operating mode (not set) it doesn't seem to matter if you spin the rear wheel by itself or not. A code has never set for me even when whistling it up in excess of 80mph. Have done this more than once. (twice?)
Hmmm.
Duane
Check the obvious first!
73 Z1 Kawi
and 7 long gone
Dman is offline
post #15 of 24 Old Mar 15th, 2006, 6:25 pm
Beemerider's Avatar
Hmmm.
You may have misinterpreted what we are stating. Yeah I too can whistle it to 80 mph with the bike stationary on the center stand w/o a problem. What I am referring to is doing this in one motion (well not 80 mph, just having the rear wheel rotating while the front is motionless) and kicking it off the center stand and then moving forward.
Ride On!
Goodyear, AZ
'13 SILVA K1600GTL
post #16 of 24 Old Mar 15th, 2006, 7:27 pm
Andy, is this something different on the later models? It was not so on my 2001 LT. I ran it in gear on the centerstand a few times, never had an ABS fault.
post #17 of 24 Old Mar 15th, 2006, 7:36 pm
David,
I have done it several times on the 05 and no problems. I thought it was just on the early bikes with out the integral set up. Looks like there is no definitive answer.
post #18 of 24 Old Mar 16th, 2006, 9:01 am
Same here. After I replaced the rear drive bearing recently, I wanted to "run in" the new bearing before putting it under a full load so I shifted the bike up through the gears to fifth on the centerstand. I let it idle in each gear for a few minutes with some increases to a moderate RPM. No faults.
Alex H Lindsay
Melbourne, FL
Champagne 2001 LT
Space Coast BMW Riders
alindsay is offline
post #19 of 24 Old Mar 16th, 2006, 9:04 am
Cat Herder
andy's Avatar
I was parroting the dealer. (BMW of Denver) And when thinking about it it did make sense to ME. The computer has to think there is something wrong with the bike if it sees totally different speeds of the front and rear wheel.
Seems that I stand corrected.
andy is offline
post #20 of 24 Old Mar 16th, 2006, 9:39 am
I don't think the ABS system checks for wheel speed until the brakes are applied, so just running the bike without using the brakes seems to be OK. I would amagine that if you were to apply the front brake while running the bike on the centerstand a fault would be generated.
post #21 of 24 Old Mar 16th, 2006, 10:13 am
Cat Herder
andy's Avatar
That can certainly be the problem. And in my spill back in 2003 when I had this happen to me I am sure I applied brakes while going down.
andy is offline
post #22 of 24 Old Mar 16th, 2006, 1:55 pm
I'm not sure if the brakes being applied is the trigger. I'd guess that it doesn't check until it gets a good signal from both wheels and completes the startup self test. If one wheel then gives a significantly different reading, a fault should occur.
But if you turn on the bike, never move the front wheel (so never complete the self test), then spin up the rear wheel there should be no fault. I think that scenarios fits the reports we've seen.
post #23 of 24 Old Mar 17th, 2006, 7:12 am
Wouldn't it have to check for a wheel signal to complete the initial self test? Isn't wheel motion and signal output what feeds the computer for the final check and then turns the light out as you first pull away after start up?
Bill McAllister
St. Louis, MO.
2003 K1200LTE
McAllister is offline
post #24 of 24 Old Mar 17th, 2006, 9:21 am
I agree with Ken's assessment, likely that the self test on start out needs both wheel sensors input to start. I know from experience that running the bike on the centerstand does not start the test, nor does it create a fault.
Don't know if my original thought that applying the front brake while running the bike in gear on the centerstand would cause a fault, since the start up self test has not happened.
ABS unit gone again plonk K1200LT 9 Jun 17th, 2011 4:06 am
Help with ABS LT2B K1200LT 15 Jun 16th, 2006 12:22 am
ABS Failure on 2000LT iowalt K1200LT 5 Jan 10th, 2006 10:20 pm
ABS reset dwspla K1200LT 1 Oct 19th, 2005 10:13 am
