ABS pressure modulator - BMW Luxury Touring Community
post #1 of 4 Old Nov 26th, 2011, 3:23 am Thread Starter
Hi all, Ive just discovered that my pressure modulator has failed. To buy this unit new is 1400 pounds sterling,its an 04 bike,ive found a breakers with an 06 LT, how can you tell if theyre compatable,and would you take the chance with a second hand one ? Theres only 7k on the one in the breakers. Not sure how it failed, could changing the pads and pushing the fluid back have caused it?
SlanePaul is offline
post #2 of 4 Old Nov 26th, 2011, 6:11 am
mreuter's Avatar
Re: ABS pressure modulator
Model change was in 05 but if the changed some thing on the ABS system, or modulator, I don't know but I doubt. Also I don't think that you do any harm to the modulator if you push the pads back in to the end position. Must be something else. Maybe you flush your system first and see if it comes back to live. In case you need a replacement.
One modulator is on the German eBay for 1750,- Euro is a new one. And on the US eBay you will find 7 or 8 of them. This are used ones and start under 500,- $
Hope I could help you
mreuter is offline
post #3 of 4 Old Nov 26th, 2011, 12:25 pm
BecketMa's Avatar
I look up parts on "MAX BMW" on line site.
AES BMW also has on line parts.
BecketMa is offline
post #4 of 4 Old Nov 26th, 2011, 3:25 pm
Lee510's Avatar
I think the European '04s are equivalent to US '05s. I've read this several times around the forum. That being the case, the ABS modules should be the same. Posting a picture of the module in your '04 would be most helpful.
Lee
2005 K1200 LT Ocean Blue
ATGATT
CCR 2009, CCR 2010, CCR 2012
IBA #39250
SS1000 - September 2009
BB1500 - September 2009
BMW MOA #167909
Lee510 is offline
ABS II problem after reset and modulator clean jackd K1200LT 4 Nov 11th, 2012 7:21 pm
BMW Bulletin on Installation of Steel Brake Lines rdwalker Bike Talk 5 Feb 12th, 2011 11:25 pm
ABS Pressure Modulator ETF 05 ZL66658 K1200LT 3 Feb 9th, 2011 7:27 am
ABS low pressure question sds K1200LT 9 Aug 15th, 2010 4:46 pm
