rear rotor and abs ring play - BMW Luxury Touring Community
post #1 of 7 Old Nov 24th, 2011, 10:44 am Thread Starter
Stoker100's Avatar
It looks like the rear rotor is attached to the ABS rung with rivets or something like that. I have a small amount of play between the two. I notices it when I was doing my rear brakes. I can grab the rotor and wiggle it left to right and it moves a little.
Is that normal?
thx
ld
Stoker100 is offline
post #2 of 7 Old Nov 24th, 2011, 11:06 am
amarider's Avatar
Re: rear rotor and abs ring play
Yes - some ring like a cow bell when your riding slow.
John & Cathy
Northern CA
01 K1200LTC Basalt - Moose
Posse #2
amarider is offline
post #3 of 7 Old Nov 24th, 2011, 11:31 am
mreuter's Avatar
Sorry, but is not. Should be on the rim and fixed to it with tree screws and a shrink fit without any play or movement. If this ring is loose or has a vertical play your ABS system can fail.
If loose, is to dangerous, watch it.
Manfred
mreuter is offline
post #4 of 7 Old Nov 24th, 2011, 11:34 am
mreuter's Avatar
Manfred
Sorry I had it wrong. The rotor can be a little loose thats right I understud the ABS Ring.
Sorry,
Manfred
mreuter is offline
post #5 of 7 Old Nov 24th, 2011, 12:11 pm
lesn's Avatar
Guten tag Manfred,
you understood correctly, but he stated it wrong. The ABS ring is solidly fixed and not attached to the rotor.
lesn is offline
post #6 of 7 Old Nov 24th, 2011, 12:17 pm
Enjoy The Ride
saddleman's Avatar
It is a floating rotor and should move front to back & side to side a little.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #7 of 7 Old Nov 24th, 2011, 2:21 pm Thread Starter
Stoker100's Avatar
It's the rotor that flexes, not the ABS ring. Got my answer.
thx
ld
