Took the clutch and housing out today. - BMW Luxury Touring Community
post #1 of 7 Old Nov 14th, 2011, 1:04 pm Thread Starter
airplane's Avatar
I finished the teardown on the clutch job i'm doing on the k1200lt its an 03 model with 98800 or so miles on it. After i removed the rear clutch housing and the rear main seal(output shaft seal) i noticed that i can move the output shaft in and out a little less than 1/8 inch. Is this normal? It did not move when the clutch housing was in place. I guess the clutch housing hex nut pulls this output shaft in to a thrust bearing when installed and torqued down.
The clutch had about 10 thousands left before it hit the rivets. There was some wear in three spots on the pressure plate. The diaphram spring had wear where the clutch rod goes and the outside edge of the center part of the diaphram spring showed signs of movement...I.e. shiny sport rubbed on the inner side of the diaphram spring. Found all the parts on line at Maxbmw. and compared their prices to Bob's BMW and they are exactly the same. I'm waiting untill tomorrow to call Bentonville BMW and check with them before I order. Are there any other good new parts places I should check.
Thanks "airplane"
airplane is offline
post #2 of 7 Old Nov 14th, 2011, 1:52 pm
Family_fun's Avatar
Re: Took the clutch and housing out today.
I believe The new BMW dealership in Chicago is offering 15% discount if you call them with the part numbers. The name escapes me, I believe it is Crossroads BMW.
If you have the part numbers, can you post them or shoot me a PM? I need to do the same job here within the next week or so. Thanks!
I'd rather have a bottle in front of me, than a frontal lobobomy!
87 K100RS Tooling round town edition
01 K1200LT Luxo-Barge
83 Yamaha XJ Turbo Forced Air Futility
83 GPz 1100 Thrashed, Trashed & Crashed
74 Honda 500-4 Mad Max reincarnate
Family_fun is offline
post #3 of 7 Old Nov 14th, 2011, 4:57 pm
Be careful and don't put any force on the output shaft while the housing is off. You can damage the oil/water pump unit that is at the other end. A little play here when the housing is off is normal.
post #4 of 7 Old Nov 14th, 2011, 5:04 pm Thread Starter
airplane's Avatar
Ok thanks for the Info. Will probably order parts tomorrow.
airplane is offline
post #5 of 7 Old Nov 14th, 2011, 5:29 pm
BecketMa's Avatar
I've used MAX for a few years now. Whenever I call they go out of their way to help with parts.
I wanted to get a pair of BMW waterproof boots for my vacation in Maine. When i was headed to western mass I passed near where they are in NH.
It was Sat and it looked like I might not make it there by their closing time. When i got there it was about 15 minutes past closing. I walked up to the doors and they were locked.
Just I was about to suite up the door opened and a voice wanted to know if I needed parts?
They invited me in and spent around 20 minutes with me as I tried on different boots.
Oh. When I order parts, if they are in stock the parts usually get mailed the same day.
Best
BecketMa is offline
post #6 of 7 Old Nov 14th, 2011, 5:37 pm Thread Starter
airplane's Avatar
I did not write the part numbers down. I just went on to Maxbmw.com and used their shopping cart and went down the list of things I need.
Use the microfish pages for the part numbers.
There is an online repair manual at scribd.com. I have used it several time this weekend to help with the trear down.
airplane is offline
post #7 of 7 Old Nov 15th, 2011, 11:03 am Thread Starter
airplane's Avatar
Hi the name is Countryside BMW Phone # 7085889900. I talked to Javier and they give Fedex shipping for 9.00. They also gave me the 15% discount you mentioned. Thanks for the heads up!
You can go thier web site and get the part number and then call them.
airplane is offline
Bellhousing, Clutch Housing, Intermediate Case, Inspection Hole bowlesj K1200LT 21 Oct 31st, 2011 11:15 pm
Clutch Housing Weep Hole Photo Dean_BMW K1200LT 30 Jul 24th, 2011 4:14 pm
RT Clutch Adjustment Nebish RT Series 17 Apr 1st, 2009 9:51 am
Unreliable clutch advice please cyclecamper K1200LT 11 Dec 1st, 2008 10:23 pm
Is it time to start drilling TWO weep holes? Dean_BMW K1200LT 10 Dec 5th, 2007 5:29 pm
