Center stand advice - BMW Luxury Touring Community
post #1 of 5 Old Nov 10th, 2011, 8:48 am Thread Starter
Center stand advice
Hi All,
I have a 2005 LT with motorized center stand. I've had the bike for 2 years and the stand has been fine. In the last few months, when I lower the stand, it lowers fine and has plenty of strength but when it gets to the last third of its stroke it hesitates. If I help it along it will complete the entire stroke.
Has anyone ever had this issue and how was it resolved?
Thank you
dabadou2 is offline
post #2 of 5 Old Nov 10th, 2011, 10:25 am
Re: Center stand advice
Originally Posted by dabadou2
Hi All,
Thank you
A quick search using EHCS (electro hydraulic center stand) turned up 62 threads on the subject. I scanned thru a couple of them and it looks to me like this topic has been covered several times since the introduction of the ECHS. Not that it's common, but then again, it isn't rare either. Good luck in finding the cure that works for your ECHS.
post #3 of 5 Old Nov 10th, 2011, 10:51 am
Bighopper's Avatar
As Dick said, look through the search function & links below the thread.
But that said, I think you will find that it is getting low on Hydraulic fluid. And if it hasn't been flushed I would suggest you do it, again you will find links to how to do it in the threads.
Here are a couple
http://www.bmwlt.com/forums/showthread.php?t=40287
http://www.bmwlt.com/forums/showthread.php?t=48253
And this is the one on the Flush Procedure.
http://www.bmwlt.com/files/displayim...album=15&pos=2
Read a re-read, the most critical is not putting too much Hydraulic fluid in of this could happen http://www.bmwlt.com/forums/showthread.php?t=46384
Good Luck
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1973 Norton Interstate
1965 Atlas 750
2014 Tour Balkans
2017 3 mth tour of Australia
2018 Tour Namibia,Botswana, Zimbabwe
2019 Tour Peru
2020 Tour Greece (Sept/Oct)
Bighopper is offline
post #4 of 5 Old Nov 10th, 2011, 5:51 pm
Hi All,
Thank you
Usually it is due to a slight leak over time. Almost always recovers following a dump of the old fluid. A small disassembly followed by a good cleaning and re-filling with 125 - 150 ml of fluid. Seals and o-rings should be good for a couple of these evolutions.
post #5 of 5 Old Nov 10th, 2011, 8:04 pm
pauleknight's Avatar
Dick were you a research librarian at one time?
you are really good at it
2009 K1200LT The Черный заяц 2 March '12 -
2008 R1200GSA Dec'11 - March '12 (sold)
2009 K1200LT The Черный заяц Nov '10 - Nov '11 (sold )
2000 K1200LT Flying Purple Mile Eater May '10 - Nov '10 (sold)
2005 VTX1300s Nov '09 - Nov '10 (sold)
pauleknight is offline
REPORT: Retrofit '01 with a Power Center Stand midwilshire K1200LT 55 May 10th, 2016 11:51 am
Installed a shorter center stand davek1 K1200LT 12 Sep 16th, 2010 12:33 pm
2002 k1200ltc center stand retrofit? rogerK K1200LT 14 Nov 26th, 2008 12:07 am
2002 Model Center Stand Broke MattKas K1200LT 7 Nov 6th, 2006 1:37 pm
Center Stand Lubrication for Pre 2005 MattKas K1200LT 9 Oct 19th, 2006 1:16 pm
