Grip Glue? - BMW Luxury Touring Community
post #1 of 13 Old Nov 5th, 2011, 11:53 am Thread Starter
Grip Glue?
Just put new grips on the LT. Problem is - have used two different types of glue and once the heat element are on for a while the glue gives way. I have used molding adhesive and regular grip glue from the bike shop. Neither held up to the grip heat.
Any suggestions what to use that will still hold when the heat is on??
Tom
Plasterman is offline
post #2 of 13 Old Nov 5th, 2011, 12:15 pm
rowie's Avatar
Re: Grip Glue?
I've never tried it but I'm told golf tape works. In the past I've used hairspray on grips and it's worked well, but I would imagine that if grip glue isn't holding, hair spray wouldn't either. I'd be giving the golf tape a shot if it were me. Hope this helps.
BMWMOA member
Current rides:
Prior rides:
Suzuki GS425E (Australia)
Suzuki T250R (Australia)
rowie is offline
post #3 of 13 Old Nov 5th, 2011, 12:20 pm
McWideglide's Avatar
Re: Grip Glue?
I have seen hair spray used for an adhesive. Harley uses super glue.
McWideglide is online now
post #4 of 13 Old Nov 5th, 2011, 1:26 pm
Re: Grip Glue?
This glue has worked well for me:
http://www.amazon.com/gp/product/B00...00_i00_details
2002 K1200LT
Sunderland is offline
post #5 of 13 Old Nov 6th, 2011, 3:31 am
mreuter's Avatar
Re: Grip Glue?
Some over here in Germany use Brake cleaner spray. Make the grip flushing easy on and after the liquid evaporate you have good connection without any slip between handle bar and grip.
Manfred
mreuter is offline
post #6 of 13 Old Nov 6th, 2011, 8:48 pm
itspossible's Avatar
Re: Grip Glue?
I just did mine and used 2 part epoxy...thats what the bike shop said they used. Hope I never have to replace them again.
2008 RT
2002 LT champagne
2003 Shadow
1986 Yamaha 500
1981 Honda Twinstar
itspossible is offline
post #7 of 13 Old Nov 6th, 2011, 10:32 pm
Re: Grip Glue?
Manfred
At a Suzuki dealership I worked at years ago, we used brake cleaner or electrical contact cleaner to help slide them on, and no glue or adhesive at all. I understood that Suzuki did the same; at least I removed a number of grips but don't recall ever seeing any adhesive on the grips or bars.
bgerrity is offline
post #8 of 13 Old Nov 7th, 2011, 1:52 am
Gino's Avatar
Re: Grip Glue?
I used this from Cycle Gear: http://www.cyclegear.com/eng/product...lue/web1006259
Only $1.99 for a small tube (best to find local shop - shipping would cost more than the glue!) You end up using 1/2 a tube or so; saves you from buying a larger tube and having it sit around for a few years waiting for you to wear out your grips!
I also put those foam rubber grips over the stock grips (2 layers) to give the grips a larger diameter and longer life (the cheap foam rubber grips wear out, not your expensive BMW ones...)
Gino
Modesto, CA
'02 Silver
For they passed a noble law,
Gino is offline
post #9 of 13 Old Nov 7th, 2011, 9:09 am
Re: Grip Glue?
Got mine from the local Honda dealer. There seems to be a fine line between too much and not enough. Make sure it has time to setup all the way before you take the bike out.
Mitch Tucker
2002 K1200LTC
1989 K100RS (Needing engine replaced)
1994 FXR, S&S 113
sk8sslow is offline
post #10 of 13 Old Nov 7th, 2011, 9:13 am
Re: Grip Glue?
I put Grip Puppies on my K1600 GTL and did not use any glue. The fit was tight and they don't move.
post #11 of 13 Old Nov 7th, 2011, 9:54 am
RonKMiller's Avatar
Re: Grip Glue?
A few drops of dish washing liquid and water... I would stay away from solvents (which of course are present in glue as well) since it will attack not only the new grip puppies but also your insanely expensive BMW (heated) grips as well.
First, do no harm...
"Like Butt-ahh!"
RonKMiller is offline
post #12 of 13 Old Nov 9th, 2011, 7:48 pm
BeachZTT's Avatar
Re: Grip Glue?
I have used hairspray on everything with handle bars including personal watercraft and never had a problem. Trick is to clean both surfaces with alcohol. The heat won't be a problem as it is with a glue.
BeachZTT is offline
post #13 of 13 Old Nov 10th, 2011, 6:49 am
Winghunter's Avatar
Re: Grip Glue?
Originally Posted by Sunderland
I also used it on my LT but , Iam working for that company as a Sales Eng , serving a part of the motorcycle and car industry, like BMW, KTM on the bike side
best regards from Bavaria
Rudy
"Winghunter"
Administrator and Chairman of the MTCG
The European Motorcycle Touring Community
Motorcycle Touring Club Germany
- Forum
Winghunter is offline
$7.00 Heated Grip Repair!! ridinredfox K1200LT 7 Jan 19th, 2012 7:56 pm
Loose Throttle Grip soul2blue K1200LT 0 Oct 17th, 2010 3:53 pm
Grip Puppies Installation SteveHill K1200LT 26 Jun 18th, 2010 3:55 pm
Rubber Throttle Grip MH60PIC K1200LT 3 Jun 16th, 2010 8:15 pm
Grip Puppies, bought 'em, like 'em! Briantime K1200LT 51 Apr 30th, 2009 6:03 pm
