Wondering if it sounds right - BMW Luxury Touring Community
post #1 of 15 Old Oct 23rd, 2011, 10:39 pm Thread Starter
Would it be OK if I post a video clip of the 2000 K1200LT Custom that I bought a couple of days ago? I was thinking that if I started it and maybe gave it a rev or two the forum goers that are familiar with the motorcycle could tell me if anything that is sounding obviously wrong could give me a heads up.
I know it won't be a definitive test, but I like in a small mountain town and the nearest dealer is probably 100 miles away and this will give me something to go on until I can get it to them for an inspection of sorts.
If this is something that has no value, please let me know and I won't waste your time.
Thanks.
CoFRBrutus is offline
post #2 of 15 Old Oct 23rd, 2011, 10:44 pm
WildBil's Avatar
Re: Wondering if it sounds right
I am not sure what the size limits here allow for, but if you can post it anywhere and link to it, I am pretty sure nobody would mind giving it a listen. I have only been around here about four years, but I have never seen anybody that needed it not get help.
Bill
wild bil
07 K1200LT Biarritz Blau
WildBil is offline
post #3 of 15 Old Oct 23rd, 2011, 11:14 pm Thread Starter
Bill
Thanks. I'll do as you suggest. It sounds good to me, but there is some stuttering, but I think that is from the dealer filling it with regular unleaded instead of premium. Ive made the assumption that it was well cared for, since every maintenance milestone was stamped by the dealer as being completed. I just want some piece of mind.
post #4 of 15 Old Oct 24th, 2011, 5:27 am
Mugszy's Avatar
The bike will not "Stutter" as a result of using regular fuel.
Mugz
BMWMOA - #45711
2006 K1200LT - Blue Baby
2003 R1150GS - Yellowbird
1981 R100CS - Sadly gone
1986 K100RS - In the past
Mugszy is offline
post #5 of 15 Old Oct 24th, 2011, 5:40 am
Boatzo's Avatar
Mugz
+1 I run regular (87) a lot these days and no problem. Try a treatment of Sea Foam in the gas.
Bill
K3ZXV
05 Honda Sabre 1100
Boatzo is offline
post #6 of 15 Old Oct 24th, 2011, 10:39 am Thread Starter
Ok, thanks for the info on regular gas.
post #7 of 15 Old Oct 24th, 2011, 9:53 pm
wa1200lt's Avatar
Zach, you can either post the vid on youtube or a service like photobucket.
Loren
WAK1200LT
Loren
wa1200lt is offline
post #8 of 15 Old Oct 25th, 2011, 10:33 am Thread Starter
Loren
Thanks for the info. Trying to find the time to do this now. YouTube is a good idea.
post #9 of 15 Old Oct 25th, 2011, 6:10 pm
Y'all can run all the regular you want. Just be aware the LT does not have a knock sensor to retard the timing. I have seen two engines so far that have all the piston ring lands fractured from detonation. Caveat Emptor. Especially the 05 and up with the higher compresion RS pistons.
post #10 of 15 Old Oct 26th, 2011, 10:58 am Thread Starter
Here is a link to the YouTube video of the engine sound. I gave the throttle a quick 1/4 twist while in N.
http://www.youtube.com/watch?v=XbXBLhrhRZM
When I started it, has been on the center stand for about 4 days, some smoke came from what appears to be the area in front of the side stand. I know smoke is normal if left on the side stand, but didn't know if it was normal on the center stand.
I know you probably can't tell a lot just from the quick clip, just wondering if you could hear anything obviously wrong.
I talked with the original owner of the motorcycle, and he said he never had a problem, except for a fork seal, which he replaced.
I'm not sure if there is a skid plate on it. Is the oil pan rear of the side stand and grey? If it is I don't think he ever had a skid plate.
I'm taking it in for it's 72K service on Saturday, I just want some piece of mind.
post #11 of 15 Old Oct 27th, 2011, 7:38 pm
Thanks.
I have heard "I'll hold the phone up to it" before, but a sound file on YouTube is a new one to me. I bit.
I heard nothing scary on your recording, it sounded like mine as far as I could tell. If you don't have any reason to think that there's a problem, ride it. Changing the oil couldn't hurt, air up the tires to 42F/48R.
bgerrity is offline
post #12 of 15 Old Oct 27th, 2011, 8:15 pm Thread Starter
Thanks. Taking it for the 72K checkup on Saturday. Don't want to do it myself for the first time.
post #13 of 15 Old Oct 27th, 2011, 9:15 pm
palarimer's Avatar
I like those Grips he has on!, anyone recognize them and know were I could get a pair, mine are starting to split.
-Preston
-Preston
02 K1200 LTC | 94 K75 RT | '02 R1150 GS
palarimer is offline
post #14 of 15 Old Oct 28th, 2011, 5:14 am
Roamrider's Avatar
Sounds like mine, which has 96K miles on it......no worries. Just ride....enjoy.
JD
Jeff Dunkle
Ocala, FL
2000 LT - Motorvation Formula II
1995 R100GS
2004 Burgman 650 (wife's)
Roamrider is offline
post #15 of 15 Old Oct 28th, 2011, 9:29 am
Sounds like mine for the most part. I have a 2000, which for the most part is exactly the same as yours. In cooler weather, I do run regular gas, and in warmer weather I run mid grade unless I am riding two up, and I use Premium. The smoking on start up is very normal.
jrlakin is offline
my sony ericson is keeping time sounds like WirelessRider Intercom, CB, & 2-Way Radios 2 Mar 30th, 2007 3:26 pm
2006 Brake Sounds...Normal? browad K1200LT 10 Dec 12th, 2006 8:18 pm
Just wondering..... Toolman Curve Cowboy Reunion 34 Aug 16th, 2006 11:36 am
Sounds Alike dfinazzo Humor 0 Jul 27th, 2006 10:45 pm
2k and was wondering a few things... TBob K1200LT 7 Feb 28th, 2006 7:11 pm
