Starting issues... - BMW Luxury Touring Community
post #1 of 5 Old Oct 16th, 2011, 6:05 pm Thread Starter
rowie's Avatar
Starting issues...
I was on a 2000 mile ride that I just got back from. While on the ride, four or five times, my 2005 K1200LT struggled to start, and on one occasion failed to start altogether until I sprayed some engine start into the air intake.
When it failed altogether, the starter turned over fine but it did not fire at all. Then I sprayed in some engine start (attempting to work out "spark or fuel") and it kicked a few times then, with copious throttle on-off application slowly fired and then ran. The next morning it struggled to start, where the starter was spinning, then after about 5-10 seconds it kicked a few times while I opened and closed the throttle, and it sputtered into life. I normally would not use any throttle to start the bike, so its not my "starting technique".
What's weird is that once it starts, it runs fine like nothing is wrong, and then it can go for a couple of days without any starting issues (starts easily with no throttle application). The it struggles again a few days later. It struggled in a very remote location which made me a little nervous...
Any ideas? I did recently change the fuel filter (and I was very particular to ensure it went on the right way), but it ran over 1000 miles before any problem, including a run on the Tail of the Dragon (actually it completely failed to start after that day). I was running in rain all day that day when it failed 1000 miles from home (literally...) but it struggled a few days later in the dry where everything should have been dry. I'm stumped....
BMWMOA member
Current rides:
Prior rides:
Suzuki GS425E (Australia)
Suzuki T250R (Australia)
rowie is offline
post #2 of 5 Old Oct 16th, 2011, 6:29 pm
BecketMa's Avatar
Re: Starting issues...
Here is a similar thread:
http://www.bmwlt.com/forums/showthread.php?t=47384
Best from Gorham ME
BecketMa is offline
post #3 of 5 Old Oct 16th, 2011, 10:05 pm
JPSpen's Avatar
Fuel pump relay..
Failure mode: Won't start till you crank it for a long time....
You crank the engine long enough for the oil pressure to come up and the oil pressure relay to kick in and turn the fuel pump on...
When you turn on the key, Listen for the fuel pump to run.. Betcha when it won't start, You didn't hear it run...
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #4 of 5 Old Oct 17th, 2011, 3:33 pm Thread Starter
rowie's Avatar
Where do I listen for the fuel pump or is there another way to be sure the fuel pump is running? I thought I heard the pump but the ABS pump is so loud that maybe I'm hearing that.... I did (at the time it completely failed) feel the lower fuel tank and it felt like the pump was starting and stopping when the ignition was switched on and off again, but again, it's possible it was the ABS pump....
And if it's that hose thing that pops off inside the tank, how do I make sure that never happens again? Thanks!
BMWMOA member
Current rides:
Prior rides:
rowie is offline
post #5 of 5 Old Oct 17th, 2011, 7:46 pm
I think Bob has you on the right path with the relay posting. Relays have a habit of working then not working, then working again. That alone will drive you nuts. Best just to replace them. I don't suspect the hose as once it is off it stays off.
Issues with Radio / Comm Chasman50 K1200LT 4 Aug 23rd, 2011 1:17 pm
Another 2005 LT starting problem gremlin Redleg_Rider K1200LT 8 Apr 28th, 2010 10:27 am
Another Trouble Starting Thread Ranger K1200LT 4 Apr 26th, 2009 1:32 pm
Voice II questions..and issues edbremer Intercom, CB, & 2-Way Radios 0 Mar 24th, 2009 10:44 pm
Chasing GT Tech Issues with Broken Processes DavidTaylor K1200/1300GT (The Next Generation) 19 Dec 19th, 2008 6:37 pm
