Side Stand Springs - BMW Luxury Touring Community
post #1 of 8 Old Oct 16th, 2011, 8:18 am Thread Starter
Side Stand Springs
How important is it to keep both sets of springs on the side stand? It seems that one set of springs keep falling off. It seems to be the outside set. Also is there an easy way to put them back on. Thanks Brian
brianf70 is offline
post #2 of 8 Old Oct 17th, 2011, 8:39 am
Boatzo's Avatar
Re: Side Stand Springs
Your stand will probably sag with out both springs. Don't know why it is coming off?
Bill
K3ZXV
05 Honda Sabre 1100
Boatzo is offline
post #3 of 8 Old Oct 17th, 2011, 2:19 pm Thread Starter
I knocked the first one off getting out of the garage, it hit the the drop off and broke it off.I replaced it and some where between the house and Tenn. last week the new one fell off. I still have one on but I guess I'll have to go and order a new one.
brianf70 is offline
post #4 of 8 Old Oct 17th, 2011, 7:52 pm
These are really handy for removal and installation.
Spring Hook
Make sure the hole (slot) in the lower part of the stand is not crushed. Often this happens with a hit and the spring will not go fully into the opening, allowing it to pop out easily.
post #5 of 8 Old Jan 24th, 2012, 9:25 pm
bulletbill's Avatar
I continue to lose my outside spring the side stand drags and bends the tab for the outside spring. any body have a solution to keeping it on. Safety wire???
Bill Jennings, fhp
Denison, TX
BMW States
BMW years and miles, 32 years 500K+
AMA, CMA, IBA, POG, MSF, FHP, etc
'99 K1200lt
'76 R900/6
Various Vintage Dirt Bikes
-Greeves (Sold), Pentons, Hodaka, etc.
Remember you are not lost till you run out of gas!
bulletbill is offline
post #6 of 8 Old Jan 24th, 2012, 9:41 pm
RonKMiller's Avatar
[QUOTE=brianf70 Also is there an easy way to put them back on. Thanks Brian[/QUOTE]
Bend the spring into a U shape by inserting in a vice or grabbing the ends with some vice grip pliers. Insert pennies in the coil - starting in the middle and work your way to the ends, alternating as you go. You can now easily hook the now expanded spring on the mounting posts or holes, then pull the pennies one at a time.
"Like Butt-ahh!"
RonKMiller is offline
post #7 of 8 Old Jan 24th, 2012, 10:10 pm
I lost both springs after a piece of metal bounced my way on the interstate several years ago. Naturally the side-stand came down and the bike died, but that's another story.
It was necessary to bend back the holder and I replaced both that were lost with a larger heavy spring from Home Depo that lasted 3-4 more years without a problem.
Ron's method of slipping in change to keep the spring stretched works. I used nickles.
post #8 of 8 Old Jan 25th, 2012, 8:55 am
Boatzo's Avatar
Nickles DANO, I always figured that you were among the more affluent on this forum
Bill
K3ZXV
05 Honda Sabre 1100
Boatzo is offline
Low Side Crash - Need Advice big_ed K1200LT 35 Sep 2nd, 2011 11:18 pm
HELP! Side stand switch mystery... pozo_izquierdo K1200LT 17 Apr 23rd, 2011 5:12 pm
What to use to cover up a slight rub mark on the top of a side case? DanDiver K1200LT 18 Apr 25th, 2010 11:49 am
Likely location of fuel leak on left side of engine? rdwalker K1200LT 5 Oct 4th, 2009 11:22 pm
