2000 K1200LT- battery change now - BMW Luxury Touring Community
post #1 of 13 Old Oct 15th, 2011, 2:44 pm Thread Starter
Changed dead battery in K1200 Lt- now the alarm won't go off so bike will not start. Any help would be much appreciated!
gailM is offline
post #2 of 13 Old Oct 15th, 2011, 3:04 pm
mwnahas's Avatar
Re: 2000 K1200LT- battery change now
You don't have the alarm remote? Its the left button to disarm.
Just Go
Cleveland Ohio
mwnahas is offline
post #3 of 13 Old Oct 15th, 2011, 3:40 pm
Some times you need to hit the disarm and arm buttons on the FOB several times to get the rolling code synced back up following a battery change.
Barring having a FOB it is time to bypass the alarm. Several articles in the Files - Technical section that walk you through it.
post #4 of 13 Old Oct 15th, 2011, 4:33 pm
going to steal your battery thread...or add to it.....I have a BMW gel battery 3 years old.....
always on a BMW battery tender...went to ride it 3 weeks ago....would not start...had enough voltage ???...charged the battery enough to ride the bike....next day the bike would not start again....charged the battery for a couple of hours on a battery charger...disconnected the battery and it has held 12.44 volts for 2 weeks on the bench...going to install the battery this evening, and not put it on the tender,.. if it does not start tomarrow, what should i look for? I have been able to get 5 years on a battery in the past with a regular non gel bettery. anything special about the gel batteries...
thank you it is a 2001 LT 44K
Loansumrider: Jim
01 LT Fast Pacific Blue ... " The Goose "
? when to ASUME, and HOW MUCH should you ASUME, safely ?
loansumrider is offline
post #5 of 13 Old Oct 16th, 2011, 3:28 am
wa1200lt's Avatar
[QUOTE=loansumrider.............. if it does not start tomarrow, what should i look for?........
thank you it is a 2001 LT 44K[/QUOTE]
Look for a new battery. Because the voltage is good does not mean the battery is capable of delivering the necessary starting current. You could take the charged battery to an auto store and let them load test it. They will hook up a load to the battery and monitor the voltage. My guess is that it will fail.
Lots of batteries out there besides BMW brand that will give you good service and cost far less. Remember that BMW does not manufacture batteries so they are labeling someone elses' product.
Search the forum for the word battery to see what folks are using. A number of the members rant about the Odyssey brand.
Good luck.
Loren
WAK1200LT
Loren
wa1200lt is offline
post #6 of 13 Old Oct 16th, 2011, 7:54 am
Boatzo's Avatar
Everything Loren says ! The load test will tell the true condition. A couple of other things:
> you may have a defective TENDER?
> Check for any loose or corroded connections on the battery and THE OTHER END of each cable both positive and negative.
> You do not need to get a BMW labeled battery and stay away from GEL batteries, get an AGM.
I have recently been seeing more on the SHORAI lithium battery. They are pricey, but small and light weight. Have no idea about longevity though.
Bill
K3ZXV
05 Honda Sabre 1100
Boatzo is offline
post #7 of 13 Old Jan 5th, 2012, 1:51 pm
johnT's Avatar
I often wondered what I would do if I was in east bumf*&% and I had to disconnect the battery for any reason...
and then found out that the battery inside my keyfob had DIED ....
I guess your screwed until you can find a keyfob battery.... right?
I think I will be looking into disabling the alarm over the winter..... (never use it anyway)
so far I'm still riding everyday.... tuesday morning was the coldest yet....
14 degrees...
but my kilimanjaro suit with heated vest/gloves really kept me warm.
the folks in work think I'm nuts...
they may be correct in their assumptions...
But I'm having a good time.
johnT is offline
post #8 of 13 Old Jan 5th, 2012, 3:01 pm
mwnahas's Avatar
Carry two fobs and/or a spare battery. Leaned my lesson when my remote started to die. Started doing that one day whilst traveling and barely got the remote to disengage the alarm. Rode to Radio Shack left the bike running incase they didn't have the battery, which they did. Bought two.
Just Go
Cleveland Ohio
mwnahas is offline
post #9 of 13 Old Jan 5th, 2012, 9:19 pm
Samir's Avatar
Just replaced my 3 year old BMW gel in my 03 LT after it slowly lost its ability to turn over the brick. I'm trying an Odyssey PC680 for $129 with shipping.
Samir is offline
post #10 of 13 Old Jan 5th, 2012, 11:40 pm
johnT's Avatar
sorry I didn't hear this earlier....
I just ordered one yesterday....
Delivery estimate: Jan. 11, 2012 - Jan. 14, 2012
1 "Odyssey PC680-P Battery"
Automotive; $96.25 free shipping
In Stock
Sold by: Amazon.com LLC
johnT is offline
post #11 of 13 Old Jan 6th, 2012, 10:15 am
ibbones's Avatar
In Stock
I'm looking for another battery to replace my 4 1/2 year old PC680 and this is good timing.
"BONES" <///><
2018 R1200RT
2002 K1200LTC--- Belle
ibbones is offline
post #12 of 13 Old Jan 6th, 2012, 12:01 pm
Samir's Avatar
In Stock
Sure -now ya tell me
Samir is offline
post #13 of 13 Old Jan 6th, 2012, 3:20 pm
As a datapoint, the Wėrker brand battery sold at Batteries Plus is a ROTTEN fit to the LT.
05 LT - Blue
03 VTX 1300s - fun while it lasted, sucked in the cold.
Rocketsled is offline
Battery question CMV K1200LT 9 Aug 26th, 2010 12:13 am
Is a 2000 K1200LT a whole lot different then later models? Humbucker K1200LT 10 Jul 22nd, 2010 10:04 pm
Time for Battery Change? NascaLT K1200LT 10 Jun 6th, 2007 10:18 am
Is a charger a charger? graydude Batteries, Chargers, & Electrical 28 Dec 11th, 2005 12:13 am
