2006 K1200LT Wiring Diagram - BMW Luxury Touring Community
post #1 of 9 Old Oct 7th, 2011, 4:19 am Thread Starter
Newport's Avatar
I have 2 Gerbing heated jackets. 1 for rider and 1 for passenger. (OK we are softies). What I need to know is how the BMW electrical outlets are wired as if they are all of the same fuse circuit it will be overloaded if I plug both in. If I have to change the wiring a circuit diagram will be handy. Where can I get this as it is not on the CD manual that I have?
Newport is offline
post #2 of 9 Old Oct 7th, 2011, 5:22 am
Re: 2006 K1200LT Wiring Diagram
Hi Ray.
Wiring diagrams are included in the Clymers Manual for the LT, it is worth buying.
About $99 locally, or check Ebay... $50-$60 in the US + shipping.
I'll send you a PM with a pdf that might help shortly.
Alternately, see if you can contact Onions (Ian) in Melb.... he may have had one from when he had the LT.
cheers
post #3 of 9 Old Oct 7th, 2011, 5:25 am
Mugszy's Avatar
Greetings,
I run my leads from the battery. You should have no problems.
Mugz
BMWMOA - #45711
2006 K1200LT - Blue Baby
2003 R1150GS - Yellowbird
1981 R100CS - Sadly gone
1986 K100RS - In the past
Mugszy is offline
post #4 of 9 Old Oct 7th, 2011, 5:39 am
gbob's Avatar
Good Morning Newport
Should not be a problem , we had no problem with rider and passenger using Gerbings jacket liners pluged into orignal sockets , seat heaters and grips on also .
Bob G
gbob is offline
post #5 of 9 Old Oct 10th, 2011, 5:21 pm Thread Starter
Newport's Avatar
Thanks to gbob and Mugzy.
As I also have Gerbing Gloves that use 2.2 amps in addition to the two jackets at 6.9 amps each totalling 16 amps that exceeds the fuse rating of 15 amps as used on the standard BMW electrical outlets.
With a 15 amp fuse I would want to keep current draw a bit below that figure so what I have done is to connect the rear outlet direct to the battery with an inline fuse.
As I have too many things connected direct to the battery I will soon fit another fuse block to tidy things up a bit.
Why have heated gloves when the bike has heated grips you may ask?
I find heated grips to be less than great as one generally wears thicker gloves when the weather is cold thereby significantly reducing the transfer of heaqt from the grips to the hands. With Gerbing the degree of warmth is a mere adjustment of a temp controller.
I may be a woose but am warm one!
Newport is offline
post #6 of 9 Old Oct 10th, 2011, 5:29 pm
Hope you also upgraded the wire to the rear outlet as it is only 1.5mm and only rated for 5.87 amps. Ned to go to at least 2.5mm (14.87 amp)
post #7 of 9 Old Oct 11th, 2011, 12:36 am Thread Starter
Newport's Avatar
Thanks for the input Jzeiler;
I wired the rear outlet using a wiring connection system supplied by Gerbing and the OD of those wires is 3.0mm. This battery connection system is made specifically for Gerbing gear so I trust it will be OK.
Without me dismantling the plastic ware from the bike I would like to know what size wire goes to the two front power outlets. Do you happen to know?
Newport is offline
post #8 of 9 Old Oct 11th, 2011, 1:18 am
Ray, you need this
cheapest I've seen, including shipping, seems to be less than US$50 all up.. especially with our $ right now.... about 1:1
post #9 of 9 Old Oct 11th, 2011, 6:34 pm
Actually I meant the internal wire from the factory fuse box to the factory outlet on the top case. All the power outlets (factory) are 1.5mm wire.
Need wiring schematic for can-bus K1200LT sittonb K1200LT 2 Feb 9th, 2011 9:19 pm
2006 K1200LT breaking, UK simon K1200LT 19 Nov 10th, 2008 3:12 pm
wiring loom diagram roryinlondon K1200LT 3 Feb 15th, 2007 4:51 pm
Ready to buy a 2006 K1200LT - Question on options Pitons98 K1200LT 9 Oct 19th, 2006 3:44 am
