Easy Mirror Repair - BMW Luxury Touring Community
post #1 of 8 Old Oct 3rd, 2011, 7:15 am Thread Starter
mreuter's Avatar
Easy Mirror Repair
As known the clip and the base for this is weak point and breaks apart easy. Mostly the front clip so as mine.
One of them broke at the base for the clip
And the other one lost the whole side
With a Dremel Tool I opened the place where the Ball Stud gets in to the clip, quite a bit
Then I cleaned this part with solvent and filled it up with Silicon
Then I cleaned the Ball Stud put a thin film of Grease around the Ball
After I screwed the Stud back in Place I put the Mirror on. Right to the end position.
I did this a few times piled always a new layer of Silicon surround the hole and squeezed it with my fingertip towards the hole. The Ball builds a little cave in the Silicon. If it is deep enough to hold the Mirror about 10 Millimeters take the Mirror on bring it in the right position if necessary fix it with tape to the Tuperware an don't touch it for the next three days that it can dry out.
No vibration, no wobble, you can take it of and on again no problem and safe you around 200,- bucks each side.
Hope this will help you in the future and safe you some Money.
Manfred
mreuter is offline
post #2 of 8 Old Oct 4th, 2011, 5:19 am
Winghunter's Avatar
Re: Easy Mirror Repair
Great job Manfred and easy to do.
best regards from Bavaria
Rudy
"Winghunter"
Administrator and Chairman of the MTCG
The European Motorcycle Touring Community
Motorcycle Touring Club Germany
- Forum
Winghunter is offline
post #3 of 8 Old Oct 4th, 2011, 9:44 am
Roamrider's Avatar
Slick technique, Manfred. My scoot is a candidate. Just added your process to my rainy day to-do list.
JD
Jeff Dunkle
Ocala, FL
2000 LT - Motorvation Formula II
1995 R100GS
2004 Burgman 650 (wife's)
Roamrider is offline
post #4 of 8 Old Oct 4th, 2011, 1:07 pm
BMWDave1173's Avatar
Great Idea!!! On my rainy day list as well!!!
2012 R1200RRT
2004 R1150R
2001 K1200LT (Traded)
1989 Yamaha Venture Royale (sold)
BMWDave1173 is offline
post #5 of 8 Old Oct 4th, 2011, 6:56 pm
Hey! That looks like a good fix! I just repaired the clip on the front of my right hand mirror using some epoxy and fishing line to anchor the clip. I followed some of the earlier posts here and it worked out pretty good. I just had a small piece of the plastic at the end of the clip break off so it wasn't as big a break as you show. So far it is holding up well.
Your idea is great. Hope it holds up for a long time.
Cheers,
Jim
1953 Ariel 350
1970 Norton Commando
1975 Honda Excel 250
1977 Kawasaki Z1000 LT
1985 Honda V65 Magna
1989 Yamaha Venture Royalle
2006 BMW K1200 LT
gladiator99 is offline
post #6 of 8 Old Oct 7th, 2011, 4:55 am
wa1200lt's Avatar
I took an even easier approach to fixing mine when the mounts let go. I took a #8 nylon screw, drilled a hole through the mirror assembly, tapped the hole in the metal plate behind the mirror and screwed them in place. They still break away. I know because my Beemer locked mirrors with my Maxim and the screw broke away just fine.
Loren
WAK1200LT
Loren
wa1200lt is offline
post #7 of 8 Old Nov 21st, 2011, 10:30 am
Manfred's easy fix works well. Did it last week, very satisfied with the results! You may want to use some wax paper on the ball side of the mirror just in case your silicone would spread beyond the greased ball. Just punch the ball through the wax paper, then grease the ball.
2005 K 1200 LT
Dean
NCIowaLT is offline
post #8 of 8 Old Nov 21st, 2011, 11:55 am Thread Starter
mreuter's Avatar
This wax paper makes it even more easy, good idea. But as I said, it is an easy repair and it works.
Manfred
mreuter is offline
Easy SS1000 gr8fulfred Northern California 8 Jul 10th, 2010 2:34 am
Brakes - Are they really that easy? blueknightga6 K1200LT 6 Nov 2nd, 2009 4:36 pm
Easy Oil Change On The Gt!!! cccpastorjack K1200/1300GT (The Next Generation) 9 Mar 10th, 2009 4:40 pm
Easy to work on Idofotos K1200LT 8 May 22nd, 2008 5:26 pm
Easy loading light trailer for towing LT ?? stevek1200lt K1200LT 6 Feb 21st, 2008 3:05 pm
