How important is this Bolt? - BMW Luxury Touring Community
post #1 of 12 Old Sep 17th, 2011, 7:56 pm Thread Starter
palarimer's Avatar
Adding HeliCoils to fix stripped valve cover bolts for my Oil leak ( a task complete!!) and I noticed the bolt in the picture is loose, essentially there are no threads in the hole at all! The bolt was just setting there, so how screwed am I with this one? Surely it's not just there for looking pretty, it's a long bolt.
Thanks for any info.
-Preston
-Preston
‘02 K1200 LTC | ’94 K75 RT | '02 R1150 GS
palarimer is offline
post #2 of 12 Old Sep 17th, 2011, 10:02 pm
Re: How important is this Bolt?
That is the left front engine mount bolt, there is one just like it on the right side. Those two bolts are what suspends the front of the engine from the frame, so they are extremely important. However, nothing can happen if the bolt does not come out, as it is in a rubber bushing in the engine support mount, the engine hangs from the frame.
If you make sure the right bolt tightens, the engine cannot move left/right, and if you can insure the bolt cannot work out the bike should be safe to ride.
It would be a pretty good job to replace the left engine support, but that is what should be done if the threads in it are stripped.
I do not remember whether the bolt screws into the bushing or the support bracket.
The bushing is part number 46 51 2 332 110
The support bracket is 46 51 2 332 863
post #3 of 12 Old Sep 17th, 2011, 10:54 pm Thread Starter
palarimer's Avatar
Thanks for the Info David, The bolt slides in out of the hole like a cheap ... well several things come to mind but I'll reserve myself... lets just say the hole seems way to wide for the bolt and is smooth inside, not even any evidence of threads. It's a blind whole, I can't push anything all the way through it.
I found it in my Clymer under cylinder head removal (page 109), Image120 part B. It mentions it in step 6A for RS and GT models but makes no reference to it in the LT section 6B. Is this just used on on RS and GT and the bolt is just a filler on the LT? It's not obvious if this is the same bolt referenced in image 122 especially since this appears to be a blind whole.
Again, thanks for any input.
-Preston
-Preston
post #4 of 12 Old Sep 17th, 2011, 11:12 pm
casualemt's Avatar
In the bmw manual, I think this is the same bolt you are looking at. Page 11.14
RICH CANNON
2000 K1200LT "a great ride"
1979 XS1100 (gone)
1986 VT500 Ascot (gone)
1972 Honda 500-4 (gone)
1961 Lambretta (way gone)
casualemt is offline
post #5 of 12 Old Sep 18th, 2011, 10:09 am Thread Starter
palarimer's Avatar
-Preston
Slight correction, it appears to be a blind hole, but i in the dark of night I put a small flash light flush to the hole and did see a glint of light coming from a crack back further under the tank, so it's not blind just blocked on the other side. The object I inserted to feel it the back side went in a good half an inch further than the bolt so it appears the bolt resting in the whole wouldn't be long enough to reach the back side and put a nut on it if things were aligned.
Still puzzled...
-Preston
-Preston
post #6 of 12 Old Sep 18th, 2011, 4:07 pm
Patric's Avatar
If memory serves me.. Isn't there a nut that goes on that bolt ? I remember having to bend up a wrench to get a hold of that nut to tighten one up the bolt. I think the other side has threads in the motor block.
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #7 of 12 Old Sep 18th, 2011, 4:25 pm
I seem to remember that there was a nut on that side and the one on the other side screwed into the engine after it went through the bushing. I have only removed those twice so far and it was a few months ago and I am over 60 now so that is a lot of strikes against accurate memory. Oh and that would be an M10 nut.
post #8 of 12 Old Sep 18th, 2011, 6:57 pm Thread Starter
palarimer's Avatar
Any thoughts to the Contrary that I could button it up and ride out the rest of this season on it then tear into it in the winter? Looks like to get to the other side where a Nut would go would take a lot time, radiator removal , etc ....
-Preston
-Preston
post #9 of 12 Old Sep 18th, 2011, 7:09 pm
rhawk's Avatar
This is from the MAX BMW parts fiche.
rhawk is offline
post #10 of 12 Old Sep 18th, 2011, 7:10 pm
sailor's Avatar
It is your bike and your life, so you can do what you want... BUT, I would NOT ride it like this, not even for a 1 mile.
I have worked on my motorcycles for more than 20 years, and I have removed the transmission and clutch on a K1200 - I know very well that there are only 2 bolts supporting the front of that engine and one large stud thru the back (transmission level).
It is irrelevant that on the K1200 the engine is not contributing to the strength of the frame assembly (because it is rubber mounted), There will be flexing and torsion on the mount and bolt of the other side, and this is NOT good.
John (Montreal, CANADA)
sailor is offline
post #11 of 12 Old Sep 18th, 2011, 8:37 pm
wa1200lt's Avatar
There are lots of bolts on this bike and it is easy to stuff the wrong bolt in the correct hole. If it were me i would get a bolt to match the one you found in the hole except 1" to 2" longer and see if the bolt catches threads. If it does then cut the bolt down to fit and ride like the wind!
WAK1200LT
Loren
wa1200lt is offline
post #12 of 12 Old Sep 18th, 2011, 9:08 pm
Enjoy The Ride
saddleman's Avatar
I'm not sure what size the nut is but you will need to at least remove the radiator.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is online now
broken abs bolt (plastic) bowdon K1200LT 3 Dec 18th, 2010 4:52 pm
K1200LT Rear shock mounting bolt Newport Shocks and Suspension 0 Nov 13th, 2010 3:25 am
Shock bolt mounting BMWphreak K1200LT 4 Apr 18th, 2007 11:46 am
Its Important lexlan Humor 1 Jan 21st, 2006 1:30 am
