brake fluid in the coolant res!!! - BMW Luxury Touring Community
post #1 of 9 Old Sep 4th, 2011, 11:55 pm Thread Starter
jwilly51's Avatar
I really screwed up and put a few ounces of brake fluid in the coolant res. How bad did is that? Safe to ride a few miles to dealer to flush the cooling system????? Feeling so stupid right now.
jwilly51 is offline
post #2 of 9 Old Sep 5th, 2011, 12:25 am
RonKMiller's Avatar
Re: brake fluid in the coolant res!!!
I would not ride it or start the engine since you'll contaminate the entire system.
Just drain or suction out the reservoir, fill with 50/50 coolant and distilled water, repeat then fill with 50/50. Since brake fluid is hydrophilic you should not have any trouble removing all traces.
No big deal as long as you don't start the engine.
"Like Butt-ahh!"
RonKMiller is offline
post #3 of 9 Old Sep 5th, 2011, 12:30 am
wrmoss's Avatar
This is only a guess on my part and there will be others who are more knowledgeable than myself that will jump in...but I would think if it's indeed a couple of ounces like you previously stated you should be okay to drive a short distance to have it flushed. If it was me however and you have the know how--it would be better to flush it in your garage. The properties of brake fluid being what they are I wouldn't want it circulating through seals and gaskets. It really wouldn't be a terribly hard procedure to do either. Just my two cents...
Wade
99 K-1200LT
wrmoss is offline
post #4 of 9 Old Sep 5th, 2011, 12:31 am
wrmoss's Avatar
You would be wise to follow Ron's advice...wish I thought of that.
Wade
99 K-1200LT
wrmoss is offline
post #5 of 9 Old Sep 5th, 2011, 6:58 am
Boatzo's Avatar
What Ron says. Plus check this thread as well http://www.bmwlt.com/forums/showthre...cooling+system
Bill
K3ZXV
05 Honda Sabre 1100
Boatzo is offline
post #6 of 9 Old Sep 5th, 2011, 8:16 am Thread Starter
jwilly51's Avatar
Cleaning it out was my first thought, too. If I was more of a wrench turner I would have the flush and fill done already. I've done it to car cooling systems but can find anything on how to flush and fill the K12LT. I am tempted to have AAA tow it to a dealer. Any links to flush/fill for idiots??? Clearly I qualify.
jwilly51 is offline
post #7 of 9 Old Sep 5th, 2011, 10:01 am
As Ron said DO NOT RUN ENGINE.
I would ad the following:
Take a garden hose and let it run in the reservoir to overflow for several minutes.
Use a turkey baster to draw off the water. You can also remove the small hose at the radiator filler neck and blow the residual out. Then refill with 50/50.
Even if you ran the engine a bit you are OK unless you let the engine get hot enough to draw from the reservoir..
It should be OK
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTL-E EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is offline
post #8 of 9 Old Sep 5th, 2011, 10:10 am
wrmoss's Avatar
http://www.bmwlt.com/forums/showthre...coolant+system
Look at post #7...hope this helps. If this is more than you think you can handle...do what Ron suggests and then drive it to the dealer.
Wade
99 K-1200LT
wrmoss is offline
post #9 of 9 Old Sep 5th, 2011, 4:54 pm Thread Starter
jwilly51's Avatar
Already done. I flushed the resivoir out with water. None of the brake fluid should have made in past----I hope. 50/50 back in the hard to read bottle.
Thanks for all your help during my recent panic attack.
jwilly51 is offline
Loss of Brake fluid beemer100 K1200LT 3 Aug 29th, 2010 1:49 pm
Never again eeejaay1 K1200LT 70 Aug 26th, 2008 10:23 pm
Question about brake fluid RT-Hollywood RT Series 2 Aug 22nd, 2008 8:56 pm
Changing Brake Fluid on 2005 rebentman K1200LT 5 Apr 3rd, 2006 8:04 pm
Brake fluid indicator issues Rich_in_Tampa K1200LT 2 Oct 2nd, 2005 11:30 am
