2002 i-ABS Question, fluid change and bleeding - BMW Luxury Touring Community
post #1 of 1 Old Sep 4th, 2011, 12:03 am Thread Starter
ColoradoGrant's Avatar
I followed the process to change brake fluid on my 2002. ( I had a front brake line rupture and believe the rear reservoir ran dry) I replaced the front 3 lines with Spieglers then replaced the front pads with Carbon-Lorraines. I followed the fluid change process to the letter. When I did the front wheel circuits I barely got any fluid to come out of the bleeder. Gradually I got more fluid to exit. The front lever finally feels good. It seemed like the servo pump was not working. I went for a cautious ride, and tried the right front bleeder again. This time the pump activated and lots of fresh fluid came out. ( I have the stand thing, so I did not introduce more air.) The ABS seemed to be working great, but then it appears to have stopped again. I now seem to be back to the residual brakes where I was before the line ruptured. When I pulled the front brake lever, I do not always hear the pump trying to activate as it should. Could there be air in the system still? Can the dealer do a more complete air purge than I can do? This is a long saga I know, but do you guys think my ABS pump is dead/dying/intermittent failure, or do you think I should try the complete fluid change process again? I have used about about 20ounces of new fluid so far.
THanks for all your collective wisdom out here!
ColoradoGrant is offline
Bleeding ABS Brakes cessna RT Series 6 Apr 18th, 2011 4:42 am
Bleeding Integrated ABS Front Control line c_ford K1200LT 3 Jun 4th, 2010 8:51 pm
Just did an easier tranny fluid change PrimePower K1200LT 21 Jul 27th, 2009 11:02 pm
99/00 brake fluid change advise andoni K1200LT 6 Sep 18th, 2008 10:01 am
Brake Bleeding Question JPSpen K1200LT 4 Oct 19th, 2005 10:04 pm
