2000 Lt Abs - BMW Luxury Touring Community
post #1 of 7 Old Sep 1st, 2011, 2:35 pm Thread Starter
Unhappy 2000 Lt Abs
Just reinstalled the final drive after a bearing failure. Took it out for a test drive and after about 10 blocks it started doing the ABS wig wag. Stopped and shut the bike off restarted and went about 200 yards wig wag again. Now it does it from the start everytime. Will disconnecting the battery help? Do I need to reset the computer and check the codes? I dont have a code reader and the closest dealer is 200 miles. Any other ideas for resolving the problem?
I guess there is always the black tape over the lights.
Also many thanks to CharlieVT for his help with my final drive.
High_Plains_Drifter is offline
post #2 of 7 Old Sep 1st, 2011, 2:55 pm
casualemt's Avatar
Re: 2000 Lt Abs
Did you check the clearance on the abs sensor on the rear drive after re-installing it?
Fluid levels up? Check your manual for the setup on the abs sensor setup/adjustment.
Yours being a 2000 model has a much simpler abs setup...
RICH CANNON
2000 K1200LT "a great ride"
1979 XS1100 (gone)
1986 VT500 Ascot (gone)
1972 Honda 500-4 (gone)
1961 Lambretta (way gone)
casualemt is offline
post #3 of 7 Old Sep 1st, 2011, 2:56 pm
Re: 2000 Lt Abs
Could the rear wheel sensor have been disturbed?
Ron
beets is offline
post #4 of 7 Old Sep 1st, 2011, 5:21 pm
Re: 2000 Lt Abs
2000 LT should have ABSII . With ABSII *the only* fault which resets itself without "Moditec" or manual resetting of fault codes is "Low battery voltage" - most likely caused by failing battery.
So if you have experienced the situation where the "wigwag" was on, but resetted in the next start - it was caused by low voltage. ALL OTHER failures must be resetted. Disconnecting battery does not do the trick.
Born to be wild so why not
C-A-D is offline
post #5 of 7 Old Sep 1st, 2011, 6:46 pm
Re: 2000 Lt Abs
Know anyone with a 911 code reader??
jrlakin is offline
post #6 of 7 Old Sep 1st, 2011, 10:19 pm
jrh2020's Avatar
Re: 2000 Lt Abs
http://www.bmwlt.com/forums/showthread.php?t=30942
Alternate method of resetting abs. I used it, it works.
Revision A
http://www.largiader.com/abs/absfault.html
The second link has a description of the fault codes, which is probably accurate, but I cannot vouch for it as I have only seen the dreaded #7 failure. I don't think the reset material in the second link is relevant to the LT.
Jim H.
Jim H.
K1200LT '00 for Touring, '73 Norton for fun
jrh2020 is offline
post #7 of 7 Old Sep 1st, 2011, 10:23 pm
wa1200lt's Avatar
Re: 2000 Lt Abs
Here is the link: http://www.bmwlt.com/forums/showthread.php?t=24561
Loren
WAK1200LT
Loren
wa1200lt is offline
2000 LT Brake flush, ABS unit bleeding? gdb32 K1200LT 9 May 29th, 2011 11:41 pm
ABS for 2000 K1200LT DWF K1200LT 7 Oct 15th, 2008 10:45 pm
What is the gap for the Rear ABS sensor on a 2000 LTC? wildwestrider K1200LT 5 May 2nd, 2008 10:30 pm
Being more specific: How is the ABS Unit flushed on a 2000 LT? wildwestrider K1200LT 20 Apr 18th, 2008 7:54 pm
