Need Parts Valve cover bolt, Fairing grommet - BMW Luxury Touring Community
post #1 of 7 Old Aug 29th, 2011, 9:34 pm Thread Starter
palarimer's Avatar
As I've been working on my oil leak I noticed I was missing a rubber grommet for fastening part of the upper fairing. The neat thing was that there was a screw for the fairing just sitting below where the grommet goes just laying on a bit of ledge not in a hole of any sort, gives credence to extra screws just hanging out in the bike to confuse one.
Also just because my stripped bolt hole wasn't enough I decided to shear off a bolt from the valve cover to make the task of getting my girl back on the road more challenging. So any advice where I can get these two parts (see pictures) would be appreciated.
-Preston
-Preston
02 K1200 LTC | 94 K75 RT | '02 R1150 GS
palarimer is offline
post #2 of 7 Old Aug 29th, 2011, 10:03 pm
lesn's Avatar
Re: Need Parts Valve cover bolt, Fairing grommet
I picked those up at the dealer but you can order them if no dealer close by...
lesn is offline
post #3 of 7 Old Aug 29th, 2011, 10:50 pm
wa1200lt's Avatar
Because they are the vastly superior black anodized torx screws you can get them anywhere you want. As long as you want to get them at your local(or distant) BMW dealer. The dealer is the ONLY place they are available.
Inferior non-anodized hex head bolts are available in the correct size at your local ACE hardware.
Loren
WAK1200LT
Loren
wa1200lt is offline
post #4 of 7 Old Aug 29th, 2011, 10:51 pm
wa1200lt's Avatar
Inferior non-anodized stainless steel hex head bolts are available in the correct size at your local ACE hardware.
Loren
WAK1200LT
Loren
wa1200lt is offline
post #5 of 7 Old Aug 30th, 2011, 12:16 am
AlaskaFish's Avatar
Wink Re: Need Parts Valve cover bolt, Fairing grommet
The rubber grommet you refer to is also known as a wellnut, and your BMW dealer will have them for $4.00 plus! They do go bad on a somewhat regular basis, so don't think this will be the only one you'll be replacing.
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #6 of 7 Old Aug 30th, 2011, 8:01 am
Here is a link for wellnuts. Found them on a google search. Wellnuts for 50 to 70 cents each. Parts fiche lists frame wellnuts on the K1200lt as M5. They also have a good selection of various stainless bolts and screws.
http://www.desmoparts.com/
I am sure there are others.
2002 K1200LT
RockyRaccon is offline
post #7 of 7 Old Aug 30th, 2011, 9:18 am Thread Starter
palarimer's Avatar
Thanks for the information everyone, it's much appreciated!
-Preston
-Preston
Valve Cover Gasket browad K1200LT 7 Jul 1st, 2008 11:45 am
Stripped Valve Cover Bolt reggosnell K1200LT 6 Feb 10th, 2008 12:22 pm
Valve Cover Bolts Torque Settings?? Kenny K1200LT 5 Jul 21st, 2007 9:08 am
Valve cover gasket sealant REWDOC K1200LT 20 Jul 22nd, 2006 9:06 pm
Pheonix Switches tiedend Lighting 3 Jan 21st, 2006 4:17 am
