Blowing fuse - BMW Luxury Touring Community
post #1 of 5 Old Aug 22nd, 2011, 4:51 pm Thread Starter
kgt1200's Avatar
Blowing fuse
Last week I noticed my horn (STEBEL) stopped working on my 2006 K1200LT. This weekend I noticed my brake light does not work either. They are on the same fuse along with the central locking system and the alarm system. I have never used either of these two. Each time I put in a new fuse it blow it.
Anyone have any clues as to what may be causing this? 15 Amp fuse. .
2006 K LT1200 Ridin'
2007 K GT1200 Sold
2005 ST 1100 Sold
1985 V65 1000 Magna Sold
1973 CB 750 4 Sold
1966 305 SuperHawk Sold
kgt1200 is offline
post #2 of 5 Old Aug 22nd, 2011, 4:55 pm
zippy_gg's Avatar
Re: Blowing fuse
15A fuse is good enough. Don't try a "bigger" fuse or you will have smoke and some burnt wire.
Your fuse is blowing most likely because there is a short somewhere. Check your wires and see when there would be rubbing.
Try disconnecting your horn, put a good fuse in and see if your brake light works. That would indicate something wrong with the Stebel wiring.
On top of the Stebel check if the + side may be touching the frame, or anything grounded.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 5 Old Aug 22nd, 2011, 6:16 pm Thread Starter
kgt1200's Avatar
Re: Blowing fuse
Thanks. I will try that tonight.
2007 K GT1200 Sold
2005 ST 1100 Sold
1973 CB 750 4 Sold
kgt1200 is offline
post #4 of 5 Old Aug 22nd, 2011, 8:16 pm
Re: Blowing fuse
Actually that is the quickest way to find the problem just put a paper clip in the fuse holer and watch for "smoke". Find the smoke - find the problem!!
Just kidding. But I too would look at the horn installation and look at the relay for shorts. They did use a relay on the horn? If not that could be the cause as the Stiebel horn draws too much current for the normal horn wire and would likely melt it.
jzeiler is online now
post #5 of 5 Old Aug 27th, 2011, 11:48 am Thread Starter
kgt1200's Avatar
Re: Blowing fuse
Can you say "DUH"? My bad. My horn is not a Stebel after all. It looks to be a Bosch. I guess that is the stock horn. I was not aware of the loud horn on a 2006 LT. When it worked it sure sounded like a Stebel. My question now is how to disconnect the horn? If I can get it disconnected and put in a fuse and it does not blow, I will know it is the horn or horn wiring causing the problem. I can feel the wires going into the horn. I am reluctant to pull them. Do you twist and pull or do they unplug straight out or what? Maybe they don't plug at all. Can anyone tell me how to disconnect the horn?
2007 K GT1200 Sold
2005 ST 1100 Sold
1973 CB 750 4 Sold
kgt1200 is offline
Help! Alarm fuse F3 keeps blowing sparky_k1200lt Batteries, Chargers, & Electrical 3 May 6th, 2013 8:44 pm
Keep blowing a fuse from Hyperlites sydvicioustx K1200LT 2 Jul 16th, 2008 5:03 pm
My 2005 Lt blowing fuse after reconnected battery n2taq K1200LT 3 Apr 23rd, 2008 5:39 pm
Fuel pump fuse blown RealWing K1200LT 9 Nov 24th, 2007 9:37 am
Centech AP-1 fuse panel and relay kit installed wcarter Batteries, Chargers, & Electrical 0 Feb 18th, 2007 5:36 pm
