1999 Will not start - BMW Luxury Touring Community
post #1 of 3 Old Aug 21st, 2011, 4:30 pm Thread Starter
hd2bmw's Avatar
1999 Will not start
I am posting this for my brother David aka DPCRXONE
Has anyone ever experience this problem
Bike turns over fine, actually farts once or twice but never starts
Bike was running fine parked it and 3 days later would not start.
Things checked
1) There is fuel in the lines (Yes there is gas in the tank)
2) Pump turns and comes to full presure (cycles off)
3) Check all fuse ..good
Could it be throttle positioning sensor? If so how to check?
Jim Connor
Afraid of what!
hd2bmw is offline
post #2 of 3 Old Aug 21st, 2011, 8:27 pm
Gold Supporter
Re: 1999 Will not start
Things checked
There have been several occasions where a fuel line came loose inside the tank. If you have fire at the plugs, but they are dry it might be worth checking. Or the fuel filter could be the problem. When was it changed last?
Jim Davidson
2007 R1200RT
hp1bmw is offline
post #3 of 3 Old Aug 21st, 2011, 8:51 pm
#2 has no bearing on pressure - the pump olny runs a short time and goes off. pressure or no pressure. Best to make sure pressure is in the lines to eliminate the fault Jim described.
TPS can allways be reset by pulling the ECU fuse. Then key on, no start, cycle throttle fully open then closed three times, key off then on and attempt start. Not likely your problem though.
1999 Will not Start hd2bmw K1200LT 5 Jul 19th, 2011 1:20 pm
Rough Start (video)!! I need HELP...please!! BlauBeeMr K1200LT 46 Feb 9th, 2011 11:37 am
Another LT That Won't Start. Vegas9mm K1200LT 9 Jul 12th, 2010 1:26 pm
2003 LT a No Start Problem knlkern K1200LT 11 Aug 26th, 2008 9:00 pm
