Brake line leak - BMW Luxury Touring Community
post #1 of 8 Old Aug 21st, 2011, 10:11 am Thread Starter
blindluck's Avatar
Question Brake line leak
I have a 2001 K1200 LT with ABS (purchased about 2 months ago) I am familiar with older sport bikes and dirt bikes none of the brake systems were anywhere close to being this complicated. My front brake lever started feeling spongy, when I got home my reservoir on the bar was low, no fluid at the calipers but looking up under the fairing there is a block?? With brake lines connected to it one line is leaking. My questions are
Loosing level out of the reservoir at the bar I assume this is the line leaking and I believe this line is just a signal line for the front brake system??? Is the line from the front brake lever a high pressure line applying pressure to the calipers or does the pressure come from the ABS unit itself?
Does my bike have power brakes? I did not get an owners manual from the previous owner and I will buy a Clymer manual ASAP
Before I start my first Tupperware party I have searched this site for Tupperware removal info and found it but have not found info on the line from the handle bar to the block?? I have found lots of brake line leak and bleeding info, so much on break lines I am wondering if I should replace them all or just have NAPA make me a new one.
blindluck is offline
post #2 of 8 Old Aug 22nd, 2011, 12:04 am
Re: Brake line leak
If one leaking, replace all at this age.
J.M.J...
Dcn Channing
post #3 of 8 Old Aug 22nd, 2011, 12:15 am
Re: Brake line leak
http://www.bmwlt.com/files/displayim...lbum=15&pos=18. That link is to Tupperware party zipped up file.
J.M.J...
Dcn Channing
post #4 of 8 Old Aug 22nd, 2011, 12:22 pm
Re: Brake line leak
If your calipers have "Brembo" on them then you have an early 2001 with ABS II. If they say "BMW" on them you have a later 2001 with the Integral I-ABS.
I suspect you have the ABS II if your handle bar reservoir went down. But you have more hoses leaking if you have the I-ABS and the fluid went down.
post #5 of 8 Old Aug 22nd, 2011, 11:23 pm Thread Starter
blindluck's Avatar
Re: Brake line leak
Thanks for the response, I think I will replace all of the hoses, I have read on other post about a kit that is available. Any suggestions on brake line replacement kits? I would rather replace them all together instead of one at a time. I am not at home so I will check to see if I have BMW or Brembo calipers. Thanks for the Tupperware pictures, I am sure I can get the plastic off just not as sure about getting everything back togetherů.
post #6 of 8 Old Aug 22nd, 2011, 11:28 pm
Chipper's Avatar
Re: Brake line leak
http://spieglerusa.com/brake-line-kit-180.htm
This is one web site.
Bill (aka Chipper)
Elk Grove Ca.
2014 K1600GTL-E
2004 RTP Work Bike(Retired)
2002 LTE Totaled Aug/2011)
1978 H-D LowRider
1975 Honda-Goldwing
Chipper is offline
post #7 of 8 Old Aug 23rd, 2011, 12:19 am Thread Starter
blindluck's Avatar
Re: Brake line leak
Thanks, I just checked them out and there is a dealer by my house. I am going with the clear line and titanium fittings. 234.00 for 6 steel braided lines... not tooo bad.
post #8 of 8 Old Aug 26th, 2011, 8:57 pm
Re: Brake line leak
Maybe you don't need to replace all the lines.
I had the exact same thing happen to me on a recent trip. Pretty scary when you are 1200 miles from home and your front brake handle pulls all the way to the throttle with no pressure.
It turned out to be the crush washer on the right angle fitting just to the outside of the ABS unit. The washer had developed a hairline crack. Just enough brake fluid had leaked out to lose all pressure in the line.
You have to remove a lot of the covers to get to the fitting. Remove the line that goes from the fitting to the ABS unit and then replace the washer. I got a kit of brake line crush washers from the auto parts store for $3. You will only need to bleed the front hand lever brake line after you replace the washer.
Good luck.
pshoffman is offline
K1200LT 2000 w/ABS Need to replace brake line GaryEdgar K1200LT 14 Jan 18th, 2011 6:29 pm
Brake Question chuckle K1200LT 13 Jun 30th, 2010 4:36 pm
Brake reservoir vent line size bigbear K1200LT 1 May 9th, 2009 7:26 pm
Brake Line question haji3 K1200LT 3 Mar 25th, 2007 6:48 pm
