2002 LT Oil filter requires too much force - BMW Luxury Touring Community
post #1 of 9 Old Aug 16th, 2011, 9:55 am Thread Starter
I have a 2002 K1200LT - I performed my first oil change using a kit: 11002300053 and filter 11.42 1 460 845/11.42 1 460 697 - when taking off the filter it required too much force - threads didn't appear to be stripped when examining - took just as much force to put the new one on - after just 1-2 turns it was binding. It almost seems like it is the wrong size filter, but after checking several times - this one is the right number. This is an OEM filter from BMW dealer.
Anyone see this problem before?
PaulDickson_VA is offline
post #2 of 9 Old Aug 16th, 2011, 11:07 am
Re: 2002 LT Oil filter requires too much force
What do the threads look like on the used filter?
I would remove the new filter and check the motor's threads with a mirror.
Is it possible that you have an old rubber seal stuck on the inside of the filter mount? Not probable, but Murphy's Law is always king.
By the way, the filter(s) should be easy to spin on and off.
wardenross is offline
post #3 of 9 Old Aug 16th, 2011, 12:29 pm
I think most of us are used to the long spin on most auto filters before reaching resistance. The LT filter snugs up pretty quick by comparison.
post #4 of 9 Old Aug 18th, 2011, 9:18 am Thread Starter
It started getting tight almost right away as I started to turn the filter on. The interesting thing is that it was just as tight taking the old one off - the dealer did the last oil change.
I will look at the threads a little better the next time I change the oil. I was hoping that someone has seen this before - doesn't look like it. I appreciate the feedback.
Paul
post #5 of 9 Old Aug 18th, 2011, 9:34 am
I suppose the old gasket came off?
J.M.J...
Dcn Channing
post #6 of 9 Old Aug 19th, 2011, 7:32 am
ltdavey's Avatar
Paul
I would take the time to address this right away.
If the the threads are crossed you can point that out to the dealer and get him to correct it.
Otherwise, its on you.
My filter spins on like butter. I've used OEM and different filters too.
Ride safe, ride smart, you're invisible; NOT invincible.
2016 R1200RTW Bronze
Before:
2009 K1200LT
2006 K1200GT
2004 R1200RT
1987 R80RT
1980 R100RT
ltdavey is offline
post #7 of 9 Old Aug 19th, 2011, 8:44 am
lesn's Avatar
Some one must have left a burr on the treads. People some times, drive a screw driver through the filter to remove, when they don,t have the proper filter wrench.
lesn is offline
post #8 of 9 Old Aug 19th, 2011, 3:37 pm Thread Starter
Good info - thanks, guys. I will check it when I open it up again next time.
post #9 of 9 Old Aug 20th, 2011, 9:20 am
So my lesson learned,
1. I was installing my oil filter after an oil change on a 2005 LT and had the same condition you are referencing.
2. I did not "figure it out" so I closed up the cover plate and added the oil
3. Traveled on the bike for over a 1000 miles over several weeks
4. One day I am passing a car, at higher RPM and my check oil light comes on
5. Engine starts sounding bad, within 30 seconds. (no oil leak on road)
6. Engine off, stuck on the side of the road
7. Trailer the bike home to find out the oil filter apparently was "cross threaded" and came off inside the oil/engine bay.
8. No visible thread damage upon dissassembly.
9. Occationally when installing new oil filter now, I get the cross threaded start,,, I stop and try a slight re-alignment. On a 2005 LT you should have several full rotations where the filter spins freely.
10. Over 10,000 since my installation issue, no problems with oil usage....
So my read from the above "thread" is the oil filter referenced is cross threaded, like mine was. Be careful, I drove quite a while before causing me a problem.
Stark
2014 1200RT
In the past
2005 LT
2002 Honda 1300 VTX
2000 Honda 750
larrystark is offline
Air Filter Replacement for 2002 K1200LT amills308 K1200LT 29 Jan 24th, 2015 8:49 am
Amsoil Oil Filter - Issue ehaughn K1200LT 10 Jul 20th, 2010 7:21 am
An Oil Man's View robasay Chit Chat 38 Jun 25th, 2009 8:28 am
Oil Filter Dilema **Help** BigH501 K1200LT 56 Mar 4th, 2009 10:59 am
BMW oil and filter mad1 RT Series 19 Aug 12th, 2008 8:26 pm
