Seal leaking - BMW Luxury Touring Community
post #1 of 10 Old Apr 10th, 2011, 5:30 pm Thread Starter
DanMartin's Avatar
Seal leaking
Any bets as to which seal is leaking and making this mess. I removed the boot from the final drive and got about a half cup of oil out.
dan martin
ID:	30999   Click image for larger version
ID:	31000   Click image for larger version
DanMartin is offline
post #2 of 10 Old Apr 10th, 2011, 6:06 pm
Enjoy The Ride
saddleman's Avatar
Re: Seal leaking
The dark fluid would seem to be from the FD. I have yet to see dark fluid when I change trans. fluid.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #3 of 10 Old Apr 10th, 2011, 7:43 pm
Re: Seal leaking
dan martin
No bets here, but with that much fluid you should be able to pull the FD fill plug and see if the fluid is low. That will tell you if it is the FD or the transmission and won't take long.
post #4 of 10 Old Apr 10th, 2011, 8:58 pm
PhillWard's Avatar
Re: Seal leaking
dan martin
G'day Dan,
That is some horrible looking crud you have over yer rear wheel and FD...(brrrrrrrrrr shudder shudder)...
I noticed a couple of drops of oil coming the rear rubber boot on Beryl Beemer wayyyyyyyyyyy back when she was still in the infant school...turned out to be the final drive pinion seal that was allowing FD oil back into the transmission tunnel...but nothing like what your pix indicate...was this a single day that this has happened or over a couple of weeks...(brrrrrrrrrrrrrr ...shivers at looking at all that crud) hahahha
BTW the pinion seal was something like $A8 and labour about $A300, plus oil
cheers
Phill
1950 Sunbeam 500cc S7 Combo
19XX BSA 500cc single B33
1960 Triumph 650cc Tiger 110
1970 Honda 750cc four K1
1999 K1200LT "Beryl Beemer"
Ulysses 18430
PhillWard is offline
post #5 of 10 Old Apr 10th, 2011, 9:02 pm Thread Starter
DanMartin's Avatar
Re: Seal leaking
It is definitely the trans output shaft seal. Transmission was 300ml low on oil.
FD was full. I changed out the seal a few months ago. Parts diagram calls for a 25x40x6 seal. My source (Applied Industrial) did not list that size.
They had 7mm wide. I figured close enough. Wrong. Got the right one on order from BMW now. Will go back in and change again.
dan
post #6 of 10 Old Apr 10th, 2011, 9:04 pm Thread Starter
DanMartin's Avatar
Re: Seal leaking
Originally Posted by PhillWard
G'day Dan,
cheers
That is several months of crud. I am not much on washing the LT. Rather ride.
post #7 of 10 Old Apr 10th, 2011, 9:11 pm
Lee510's Avatar
Re: Seal leaking
You didn't see what came out of the '05 a couple weeks ago. At nearly 16,000 miles, I doubt it had ever been changed since the 600 mile service, if a dealer does that then. Lots of "smudge" on the magnet. My FD fluid is never that dark. I change it when I change the engine oil at 5000 mile intervals.
Lee
2005 K1200 LT Ocean Blue
ATGATT
CCR 2009, CCR 2010, CCR 2012
IBA #39250
SS1000 - September 2009
BB1500 - September 2009
BMW MOA #167909
Lee510 is offline
post #8 of 10 Old Apr 11th, 2011, 9:16 am
Chipper's Avatar
Re: Seal leaking
Dan don't forget to change out your rear brake pads.
Bill (aka Chipper)
Elk Grove Ca.
2014 K1600GTL-E
2004 RTP Work Bike(Retired)
2002 LTE Totaled Aug/2011)
1978 H-D LowRider
1975 Honda-Goldwing
Chipper is offline
post #9 of 10 Old Apr 12th, 2011, 7:53 am
Re: Seal leaking
Sorry to perhaps digress.
Just bought a 2009 LT 3 months ago. Put in about 2000 miles on it so far. When just bought, the oils were changed by a mechanic. Out of curiosity I checked the final drive fill plug by opening it and noticed the oil was stained. Changed it and the magnetic plug was chockful of metal fragments. Just redid it today after about 500 miles and still with the crud. Am I to be worried. The bike was previously hardly ridden for perhaps about a year. Mileage now is about 28000 miles.
Should be very concerned. Plan to change / check the FD oil again in about 500 miles.
krider08 is offline
post #10 of 10 Old Apr 12th, 2011, 9:31 am
Re: Seal leaking
Kelly - on your description, things don't sound too good. However, there is nothing better than a picture of your drain plug, coated as it comes out of the final drive. The final drive experts here can usually make a reasonable 'best estimate' once they've seen that. I do know that if you see fragments/slivers of shiney metal among the film of fluid and smoodge - distinct probability that something in the final drive needs attention. I'm wondering why the mechanic who changed the fluid didn't find the same results as you did, on the drain plug. Stay tuned for an experts opinion, and good luck.
R1200GS Fork Seal Leaking niobium GS Series 5 Feb 14th, 2009 3:22 am
To fix leaking trany seal or not? BecketMa K1200LT 8 Dec 9th, 2008 11:04 pm
Shaft seal pulling made easy Schweintechnik K1200LT 4 Aug 6th, 2007 6:21 pm
Tranny Seal Leaking....Again! DaddyDukes K1200LT 2 Jun 22nd, 2007 11:25 am
Leaking Fork Seal rglassma K1200LT 7 Apr 18th, 2007 8:50 pm
