2006 LT Horn Relay - BMW Luxury Touring Community
post #1 of 6 Old Apr 10th, 2011, 11:50 am Thread Starter
roadking04's Avatar
2006 LT Horn Relay
Horn not working on my 2006 LT. Fuses are good on same fuse as alarm. can anyone tell me horn relay is located?
Tim
roadking04 is offline
post #2 of 6 Old Apr 10th, 2011, 12:18 pm
Re: 2006 LT Horn Relay
Tim
Don't know if ole Toad's (a '99) is same as '06, butt if so, it's in the electronics box under the fuel tank and shares the same duplex house as the air filter box. Slight pita and would be nice if you had other service to do near there!! Good luck.
BTW - IF you go in and the locations and sorting are the same as on a '99, the horn relay is on the outside row, second from left.
post #3 of 6 Old Apr 10th, 2011, 2:34 pm
These relays are not known to fail. I would check the ground on the horn if fuse F12 is good.
post #4 of 6 Old Sep 24th, 2011, 6:50 am
I have perhaps a unique problem.on 2000 K1200T
Battery was dead, jumped it off a car that was running.... I know NOW that is not the best thing to do.
Here is the issue, it started on the jump. I turned it off and now it won't start at all, BUT the horn is on continually. I unplugged both horns and still no start.
I talked to the local dealer / techs and they suggested I replace the horn relay. The question now is which one of the under tank relays operates the horn.
And next how do I fix the no start.
I have read all about the stuck starter relay, but that is where the starter is running all the time. Mine starter won't do anything.
Help - I want ride!!
moneyseeds is offline
post #5 of 6 Old Sep 24th, 2011, 11:32 am
zippy_gg's Avatar
The first step I would take is to disconnect the battery and leave it off for a good hour before reconnecting. The electronics are sensitive to current drops and some may need to be reset.
How did you jump start the bike? Did you connect the cables directly to your battery terminals or did you just connect to the positive and use the frame as negative (Ground)?
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #6 of 6 Old Sep 26th, 2011, 2:30 pm
When I jumped the bike, I connected both leads from the car directly to the bike battery.
Wiring info needed for the redesigned starter relay. zuchero K1200LT 27 Jun 26th, 2016 8:00 am
My new stebel horn isn't working Bobnoxous Batteries, Chargers, & Electrical 9 Aug 29th, 2009 6:52 am
Help with switch idea jarhead354 K1200LT 13 Feb 27th, 2009 11:18 am
Stebel Nautilus Compact installation Randy K1200/1300GT (The Next Generation) 11 Aug 5th, 2008 8:01 am
Oops, I let out the magic smoke jkersh1 K1200LT 4 Oct 27th, 2005 8:36 pm
