Input shaft seal installed too deep??? - BMW Luxury Touring Community
post #1 of 9 Old Apr 8th, 2011, 7:50 pm Thread Starter
rkdrmr1's Avatar
Red face Input shaft seal installed too deep???
So, I'm in the middle of my clutch / main seal replacement and, I measured the depth of the input shaft seal, (5.2mm), I installed the new seal too deep, (7.0mm). My question is: Does 1.8mm matter??? We are talking 0.07"???
Any advice from you fellow wrenchers out there would be appreciated.
Brian
rkdrmr1 is offline
post #2 of 9 Old Apr 8th, 2011, 8:53 pm
johnT's Avatar
Re: Input shaft seal installed too deep???
Your fine.
If your worried about it leaking, it won't.
There IS an oil flow channel on the backside, but you would really have to push the seal in extremely far to block it off.
I won't get into a long explanation, but even if you did block off that channel..... it wouldn't matter much.
the input seal on the outbound side is the one you have to be careful with... the oil flow channel is closer to the edge and directly exposed to the edge.
johnT is offline
post #3 of 9 Old Apr 8th, 2011, 9:01 pm
Brian,
Tough call without one open to look at. I would look closely at the shaft to see how it looks on the lip of the seal. Maybe even set it face down over night (with oil in the tranny) and look for seepage. The seal is cheap enough if you are not sure - but tough to do over if it leaks down the road. If the dealer is close and has another it might be worth the peace of mind.
P.S. I would go with what JohnT just posted while I was typing. He was just into his tranny all the way!!
post #4 of 9 Old Apr 8th, 2011, 9:29 pm Thread Starter
rkdrmr1's Avatar
So, I'm good to go?
I just cannot see a 1.8mm difference making it worth replacing the seal... Hope I'm right
John Z: Would you replace it?
rkdrmr1 is offline
post #5 of 9 Old Apr 8th, 2011, 9:33 pm
Like I said - go with johnT's recommendation. It appears you are not too deep and his is apart to measure. I would trust what he said.
post #6 of 9 Old Apr 8th, 2011, 9:37 pm
johnT's Avatar
Originally Posted by rkdrmr1
So, I'm good to go?
Here ya go.
johnT is offline
post #7 of 9 Old Apr 8th, 2011, 9:51 pm Thread Starter
rkdrmr1's Avatar
So, you wouldn't worry about 2mm damming it up and smoking it?
rkdrmr1 is offline
post #8 of 9 Old Apr 8th, 2011, 10:00 pm
johnT's Avatar
smoking what?
the bearing?
the trans uses NSK sealed clean bearings. they are not a typical fully sealed bearing though...
the sealed clean bearings do allow oil into the bearings, which eventually replaces the initial grease charge. so they get oil from each side. the oil channel is not essential to the bearing getting oil. just a plus.
your good.
johnT is offline
post #9 of 9 Old Apr 8th, 2011, 10:20 pm Thread Starter
rkdrmr1's Avatar
OK cool. I was worried most about it leaking...being set in too far.
Thanks alot for your help!
Brian
rkdrmr1 is offline
RTV Sealand on Slave input seal CARNEYM K1200LT 5 Jan 27th, 2008 8:38 pm
Transmission Seal Leak 3rd time?? mark1rob K1200LT 1 Oct 22nd, 2007 3:21 pm
Rear Main Seal Replaced but - Drip, drip rglassma K1200LT 16 Oct 8th, 2007 10:05 pm
Shaft seal pulling made easy Schweintechnik K1200LT 4 Aug 6th, 2007 6:21 pm
Clutch slave, Rear Main & Transm Input Tourdog K1200LT 7 Sep 17th, 2006 10:02 pm
