'03 LTE radio help needed - BMW Luxury Touring Community
post #1 of 3 Old Oct 18th, 2010, 12:14 pm Thread Starter
My radio has been acting up. here are the symptoms:
Turns on and works fine.
After awhile, controls won't work but it keeps playing. Then goes out completely and a "No Radio" message appears.
intercom, phone, radar, aux input(ipod) all still work fine.
I charged up the battery and radio worked for awhile and then did the same thing.
Battery seems to be holding a charge and all other electrics work fine.
Any ideas?
Thanks for any help.
Ron
byke33 is offline
post #2 of 3 Old Oct 18th, 2010, 1:40 pm
Re: '03 LTE radio help needed
Any ideas?
Ron
Hey, Ron - kinda sounds like it's on it's way to radio heaven. However - try the battery disconnect for a half hour or so. That process has fixed some other radios with similar problems. No guarantee, but worth a try.
And after you hook the battery back up, do the TPS re-set at the throttle grip:
Key on - no start.
Twist throttle wide open and release (twice)
Key off.
Key on - start the engine and ride around the block.
Good luck.
post #3 of 3 Old Oct 18th, 2010, 2:22 pm Thread Starter
got it disconnected....forgot about the tps reset...thanks Dick.
byke33 is offline
Radio just quit atps1234 K1200LT 62 May 29th, 2017 10:43 pm
2002 LT with radio problems VaBeachLT K1200LT 8 Jun 19th, 2016 5:30 pm
Help Trouble Shooting Dead Radio Lynn_Keen K1200LT 9 May 16th, 2009 1:29 pm
Radio Nedded Hollywood K1200LT 2 Apr 19th, 2008 8:39 am
