2002 K1200lte Gps - BMW Luxury Touring Community
post #1 of 15 Old Jun 3rd, 2010, 8:36 pm Thread Starter
2002 K1200lte Gps
my gps went bad on my 2002 k1200lte and I was wondering if I want to keep all functinality do I replace it with the same model or are there others that work (just like the priginal through the com system)? Where would I go about finding an original GPS unit? Also I am looking to retain the priginal mounting location hence the original replacement. thanks
Drumbum is offline
post #2 of 15 Old Jun 3rd, 2010, 9:41 pm
Re: 2002 K1200lte Gps
I don't think you'll want an original 02 GPS. Street Pilot III was way too slow. For around $300 you can get a 2820 or better that works 100 times better. Worth a new wire job. Lots of ways to get it to work on the same bracket too.
post #3 of 15 Old Jun 3rd, 2010, 11:04 pm
"that works 100 times better" is an understatement. Way, way better.
I had an SPIII and can confirm that. Currently, I have a Street Pilot 2820 and a 2610 (the latter one updated with with current maps - almost as good as the 2820, though the display does not come close).
The 26xx/27xx/2820 series are great receivers, well worth the effort to find one and to install it.
Robert in Northern NJ
rdwalker is offline
post #4 of 15 Old Jun 4th, 2010, 4:06 am
DMiller's Avatar
Yep, I made the changed and I'm glad I did it. The 2820 is much easier to use with the QWERTY keypad and it is way faster too. Don't overthink it, just do it.
DMiller is offline
post #5 of 15 Old Jun 4th, 2010, 12:18 pm Thread Starter
will the 2610 work with the com system and stock mount? I have one of those laying round..... worse case ill pop on my nuvi but wanted to keep all the functinality from the original
Drumbum is offline
post #6 of 15 Old Jun 4th, 2010, 12:33 pm
strsout's Avatar
Think about Garmin Zumo 550 or 650.
I have one on my 2002 LT, replaced the old Garmin.
You can see pictures here:
http://viajareua.com/motozumo.html
Loma Linda - CA
IBA#14,458 - AMA
strsout is offline
post #7 of 15 Old Jun 6th, 2010, 12:13 am Thread Starter
would love to get a newer bike specific one but to expensive but they sure are nice I picked up a used Nuvi that has bluetooth and mp3 player built in. Itll do everything I need. Thanks
Drumbum is offline
post #8 of 15 Old Jun 6th, 2010, 7:53 am
kellenbenz's Avatar
Before you give up on your old unit, try a master reset following the instructions in the link below. My unit appeared to have died....so I googled it and found this. It worked for me!
http://www.motorcycle-navigation.net...ard-reset.html
Ron
IBA 45658 MOA167437
Total BMW miles 509,508
Goldwing miles 238,383
kellenbenz is offline
post #9 of 15 Old Jun 6th, 2010, 8:50 am
Ron
Hey, Ron - wonder if that'll work on my Streetpilot 1?? Course, the damn thang only shows ole roads in my county, so what the heck!!
I did pick up a 2820 last year, butt have been waiting on the 8 year old next door to graduate. He did, so now he'll have time to show me how it works!!
post #10 of 15 Old Jun 6th, 2010, 10:59 am
DMiller's Avatar
The only problem with the Nuvi is its waterproofness, or lack thereof. I'm sure we have all been riding in the rain at some point.
DMiller is offline
post #11 of 15 Old Jun 6th, 2010, 11:07 am
kellenbenz's Avatar
It sure is worth a try Dick.
He made an error typing the instructions but it was easy to decipher....I will correct it below
With the unit switched off
Press the cursor button in any direction at the same time press the power button
Let go of the power button, but continue holding the cursor button
Press together the route and quit button, while you hold these two, let go of the cursor button
The unit should now make a bleep sound. Now release the route and quit buttons
The screen goes blank for about 10 seconds, then restarts
Remember to have the key on so that power is available but the unit turned off to start out.
I hope it works for you!
Ron
IBA 45658 MOA167437
post #12 of 15 Old Jun 6th, 2010, 11:42 am
haughty's Avatar
DOnt you avoid them new roads anyway?
I always thought the best roads were the old FM and RR anyway...
Don't be afraid to say what you feel, as those that matter DOnt mind and those that mind Dont matter.
Dr.Suess-
1980 YAMAHA XJ650 MAXIM (RIP)
1982 YAMAHA 750 VIRAGO (SHES GONE)
1982 SUZUKI GS1000 (GONE)
2001 BMW K1200LT
2004 BMW R 1150 RT Sold.....
2007 BMW R 1200 GS
1986 BMW K100RT WITH A FLEXIT SIDECAR
1985 BMW K100 RT ( parts bike, but its too nice to do that, so it runs)
haughty is offline
post #13 of 15 Old Jun 6th, 2010, 2:02 pm Thread Starter
ive got it sorted now. The original owner had the batteries in it (needed to make it work even if pluged into power) and that was the issue. Evedently it had gotten wet inside the battery tray and the cells poped acid all over which ate through the plastic casing and got onto the circut boards inside and ate them all up so its toast. I poped an old 2610 on there and it works fine ecept that it only has the main roads and hiways but none of the smaller roads so its pretty useless as well. The Nuvi 360 is what ill use for now until I can afford a bike specific model. the Nuvi 360 will mount up fine, interface with my phone and the com system but ill need to either water proof the case or add a waterproof case to it. there a re a number of cases thatlll work while still allowing use of the touch screen. Thanks for the replies all
Drumbum is offline
post #14 of 15 Old Jun 6th, 2010, 3:03 pm
zippy_gg's Avatar
Wink Re: 2002 K1200lte Gps
1982 GL1100 rode 84108 miles (bought with 12012 and sold at 906120)
Ron, that sure is a lot of miles on that Wing, or did you enter the Zip code instead?
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #15 of 15 Old Jun 6th, 2010, 3:51 pm
kellenbenz's Avatar
Giles....looks like I mistyped that one didn't I....thanks for the heads up.
Ron
IBA 45658 MOA167437
GPS for 2002 K1200LT E DesertCoyote K1200LT 4 Jul 29th, 2009 9:43 pm
New (to me) 2002 LTE - GPS question kaswahn GPS 8 Dec 25th, 2008 11:38 pm
What Batteries Steve_R GPS 8 Feb 5th, 2008 2:54 pm
