No front brakes - weird... - BMW Luxury Touring Community
post #1 of 19 Old May 28th, 2010, 5:35 pm Thread Starter
Question No front brakes - weird...
Bike parked, brakes are a bit spongy, but work, roll 1/2 bike length, no front brakes at all!
Blead the front brakes, blead the ABS unit, no change.
Rebuilt the master cyl. No change.
Bike parked, got brakes, disconnected battery ground, got brakes, roll back length of bike, absolulty no brakes at all in front.
Leave bike for an hour, got brakes, roll a bit, zero brakes.
Disconnecting the battery was to eliminate the potential that the ABS was doing something, so ABS eliminated as suspect, BUT with battery disconnected there is no electronic connection between the rotation of the wheel, and the brake system, there is no physical connection to the brake system, the pads are new and not dragging.
I have worked on bikes and cars for decades and seldom have a problem figuring out what is going on, but this one has me stumped.
K1200LT January 2000, ABS II
And i was all set to spend the weekend on my bike!!!
ClaytonB is offline
post #2 of 19 Old May 28th, 2010, 7:27 pm
Re: No front brakes - weird...
This is strange. Be aware there is only about two teaspoons of fluid in the ABS unit (it has a very small active chamber despite its size). So I would not suspect it.
I would however suspect the front hoses. They may be deteriorating on the inside and during that rolling movement the flex causes it to clog up at the weak point. Then as it sits the area relaxes and allows some fluid flow. Given it is a 2000 I would seriously look at replacing all the rubber hoses in the brake system.
post #3 of 19 Old May 29th, 2010, 12:54 am Thread Starter
In the morning i will put it up so i can rotate wheels while the bike is not moving.... if no loss of braking, then time for new hoses... braded SS perhaps...
When i blead the ABS, i got a tablespoon of dark fluid, then some nice clear stuff, but no air.
Thanks for the idea.. I will report back tomorrow. Had the bike since last Christmas and not had it on the road, one problem after another, thought i had it done!!
ClaytonB is offline
post #4 of 19 Old May 29th, 2010, 12:57 am Thread Starter
One thought.. if the hoses are cloging up, that would make it hard to apply the brakes; in this case there is no brake at all, lever goes right to the grip, and the bike keeps rolling. I will test the theory anyway.
ClaytonB is offline
post #5 of 19 Old May 29th, 2010, 1:27 am Thread Starter
Given your suggestion and reading "Brake hose failure registry?" thread, i think it is prudent to just replace ALL the hoses before I hit the highway.
I will still report back here tomorrow on what i find....
ClaytonB is offline
post #6 of 19 Old May 29th, 2010, 5:57 pm
If the lever is going to the grip and you are not squirting brake fluid anywhere I would suspect the master cylinder is shot.
post #7 of 19 Old May 31st, 2010, 3:57 pm Thread Starter
Question Re: No front brakes - weird...
Continued....
I put the bike on the centre stand, jacked it up so I can rotate the front wheel, tried the front brake - spongy, but working. Rotated front wheel, lever goes to the grip, zero brake. One pump and i have brake.
Got my neighbour to help. He tried the brake, ok, 1/4 rotation, some loss, 1/2 rotation more loss, 3/4 rotation, lever to the grip. Let it go, got brakes.
This is not only weird, but as far as i can see, it is impossible.
I will order a set of ss lines Tues, put them in when they come, and see if there is a difference. Hopefully Spiegler ships to Canada.
Any comments???
Anyone want to see a video of this?
ClaytonB is offline
post #8 of 19 Old May 31st, 2010, 6:24 pm Thread Starter
Cant find any leaks anywhere, and bf not going down. Master Cyl was my first thought, rebuilt it at the start.... made no difference.
ClaytonB is offline
post #9 of 19 Old May 31st, 2010, 7:10 pm
Axle's Avatar
do you have the 2 resivours under the seat.? I missed the back one when I bled the brakes it feeds the front brakes got air in the system, that threw me for a while it is so easy to miss.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #10 of 19 Old May 31st, 2010, 7:11 pm
weekendrider's Avatar
Sounds like you have warped or improperly seated rotor. When the wheel rotates, the rotor is moving side to side and pushing the pistons back in the calipers.
weekendrider is offline
post #11 of 19 Old Jun 1st, 2010, 12:42 am Thread Starter
The bike does not have dual reservoir under the seat, only one.
The idea of a warped or out of line rotor is worth investigating... thanks.
Brakes are still spongey even with a full bleed, so I will put new flex lines on anyway, but check out alignment of rotor asap.
ClaytonB is offline
post #12 of 19 Old Jun 1st, 2010, 2:09 am
Axle's Avatar
well I will watch this thread with interest
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
post #13 of 19 Old Jun 1st, 2010, 3:48 pm
If you are going to replace the lines anyway why not prove out the MC is good by pinching off the line and giving it a squeeze, just to see if it is bypassing.
post #14 of 19 Old Jun 1st, 2010, 4:47 pm
hmmmm90s's Avatar
Check your master cyl fluid level - I had similar symptoms and the OEM line had ruptured INTERNALLY - most likely location is at or near the junction block up inside the fairing nose where there is a lot of flexing going on --
it only took a littl bit of troubleshooting to realize the fluid was going from the inner line into the outer jacket of the oem line -- once i'd pumped enough fluid in there IT ruptured too and then it was easy to see what was going on. =8-o
g.
greg shamieh boof # 93 k-whiner # 83
jefferson, maryland
2000 K1200LT --- "darkside"
75R90S -- "esssss"
73R75/5 -- "mojo"
hmmmm90s is offline
post #15 of 19 Old Jun 1st, 2010, 4:57 pm
JPSpen's Avatar
When my rear master cylinder line failed. I didn't see any brake fluid at all....
The line was just blowing up like a baloon... The fluid would return and not leak out..
There's not much fluid movement for just one pump of the handle.
Changed out that line and it was solid as a rock again..
Good Luck,
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #16 of 19 Old Jun 1st, 2010, 8:00 pm
GlennM86's Avatar
I am the simple minded member of this forum, but here goes.
Did you just start your bike and this all happened? or did you drive it the required distance/speed for the LT to complete it's self test?
I ask only because when I take my LT off of the center stand the brakes act just like you describe. My brake light is still flashing on the dash because I have not reached speeds of 2-3 mph to complete the self test.
Again, I ask only because I did not see any comments that you had ridden it, only that you had gone 1/2 bike length.
Good luck. I will be following this thread becuase all of the proposed solutions make for a great knowledge base.
Glenn
Iron Butt Membership # 45813
<By Motorcycle>
<By Car or Ship>
GlennM86 is offline
post #17 of 19 Old Jun 2nd, 2010, 12:27 am Thread Starter
Smile Re: No front brakes - weird...
Mystery solved, and the prize goes to "weekendrider" for suggesting a warped rotor.
I put a dial gauge on the fork and measured the run-out of the rotor at each of the attachment points, and found a .032 difference in one section. I shimmed the rotor enough to get +- .005 and the problem dissapeared. That little difference was pushing the pad .032" into the caliper and that was enough that the master cyl could not push enough fluid volume to push the pad back to the rotor.
This weekend I will use some ss shim stock to get it +- .002" or closer and there should be no problem.
The suggestion of the "ballooning" of the rubber hoses is something i considered (thanks hmmmm90s) and high on my priority list is new SS lines; the back was replaced before i got the bike, the the two front and the handlebar hoses are the original and 10 years old... they get replaced asap!
If this rain ever stops I will finally be back on the highway
Thanks everyone from the cute little seaside village of Chemainus.
ClaytonB is offline
post #18 of 19 Old Jun 2nd, 2010, 7:36 am
Axle's Avatar
Well done
I must admit I had a bit of a chuckle at that one and I would NEVER have thought of it
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
post #19 of 19 Old Jun 2nd, 2010, 6:17 pm
Glad I could help, I've taken a ton of info from this board, feels good to give some back.
That problem is very common on Harley's with floating rotors. The rotors would warp if you looked at them wrong when taking wheels on and off.
Front wheel removal eibacher K1200LT 20 Dec 13th, 2012 10:56 pm
Bleeding brakes K1200LT Caveno K1200LT 7 May 5th, 2008 3:40 pm
02 Front Brakes Grabbing / Pulsing vipergman2 K1200LT 6 Aug 16th, 2006 7:30 pm
Front Brakes BMWeasyrider K1200LT 9 Apr 26th, 2006 10:58 am
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 11:37 am
