6-disk changer removal ? - BMW Luxury Touring Community
post #1 of 5 Old May 22nd, 2010, 5:56 pm Thread Starter
I have a 2003 LT I tried to remove my 6-disk changer from the trunk area to gain a little more luggage space since I don't use it anymore. After unplugging and removal I found that my radio no longer works. The display will light up when turned on like it is getting power but there is no display or sound of any sort. I tried plugging it back in thinking that maybe it was some sort of a loop but still have the same problem. Does anyone know if there is a fuse that may have blown under the stingray maybe? Any other suggestions.
Thanks Bob
rsharp is offline
post #2 of 5 Old May 22nd, 2010, 6:08 pm
Bighopper's Avatar
Re: 6-disk changer removal ?
Thanks Bob
Bob,
Try disconnecting the battery (neg cable) for 20 mins or so then reconnect to see if that helps (resets the radio). Taking out the 6 Disc player doesn't affect the radio other than you don't get access to the player :-).
BIGHOPPER (Phil)
BGB 602
2006 K1200LT Grey
1973 Norton Interstate
1965 Atlas 750
Bighopper is offline
post #3 of 5 Old May 23rd, 2010, 2:27 pm
The controller may have gotten "confused" when you pulled the changer. The battery disonnect reset will help. Removing the change does not disable the radio. Also press the CD button to step it back to radio.
post #4 of 5 Old May 23rd, 2010, 3:48 pm Thread Starter
Instead of waiting for some good advice I decided to remove my side covers and the control unit of the radio and look for a problem which I did not find. I had my mind made up that it had just fried the unit and I was going to get another one. Then I decided to look and see if someone came to my rescue and to my surprise you are correct. I plugged everything back in and powered it back up and it works great. I only wish that I would have checked before doing all of the extra work. Thanks again for the advice, it saved me quite a lot of money.
rsharp is offline
post #5 of 5 Old May 23rd, 2010, 9:04 pm
It is well after the fact, but you should remember never to work on disconnecting / reconnecting major parts of an electronic system (including your computers at home!) while the thing is powered up.
Fist things first:: battery off! Then do your stuff and reconnect the battery.
Robert in Northern NJ
rdwalker is offline
CD changer removal rattler50 K1200LT 2 Jan 7th, 2007 12:41 pm
Rear Brake Disk - What do we have to replace markbreen K1200LT 12 May 3rd, 2006 8:08 am
CD Changer Removal wing2pc K1200LT 4 Jan 8th, 2006 12:26 am
