High Idle - Lower MPG - BMW Luxury Touring Community
post #1 of 3 Old May 11th, 2010, 10:28 am Thread Starter
kevincook's Avatar
I haven't looked into the problem yet but for the last couple of weeks I generally have a high idle. Usually around 1200-1300rpm. If I blip the throttle it will drop back down to around 1000rpm. At the same time I have noticed that my mileage has dropped down considerably, down to around 35mpg.
Any ideas before I dig in?
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #2 of 3 Old May 11th, 2010, 11:08 am
VRodPete's Avatar
Re: High Idle - Lower MPG
Crappy fuel mileage is probably due to "winter gas" and the cool temperatures this time of year. I see tremendous swings in fuel mileage early/late in the season vs. mid-summer.
Did you do anything to the bike over the winter? In particular disconnecting the battery or letting it go dead? If so, the high idle problem may be due to that, and you will have to reset your throttle position sensor (TPS). To do that, turn the bike to ON, then rotate the throttle 3 times to full throttle and back to idle, then turn the bike OFF. After that it should have reset the sensor and your idle will (should be...) normal. It could also be a sticking throttle cable as well, but I'd put my first money on a TPS reset.
Live Slow... Fly Fast
Check out our
blog that chronicled our trip to Alaska and back.
<- The Boy
The Toys
2001 K1200LT-C that's been to the Alaskan Arctic Circle and back
2008 VRSCAWA H-D V-Rod with a few goodies
2005 VRSCA H-D V-Rod
1981 Mooney M20J
VRodPete is offline
post #3 of 3 Old May 11th, 2010, 2:38 pm Thread Starter
kevincook's Avatar
Pete,
I've been riding almost everyday for the last couple of months so it isn't something from sitting over the winter.
After doing some reading it looks like it might be the O2 sensor, low voltage sensor or possibly the TPS is going south.
Kevin
Never Again!!!!!!!!!!! JTEC K1200LT 75 Oct 16th, 2014 8:44 am
Engine will not idle eaglepilot427 K1200LT 15 Apr 25th, 2009 9:58 pm
Are You Looking For A lower Stock Heated Seat For Your LT asleeplessknight Other Stuff 1 Sep 12th, 2008 4:49 pm
HID High Beam - Would you buy again? kevincook Lighting 7 Jan 7th, 2007 8:45 pm
Lower fairing vibration at startup Jerrod Maguire K1200LT 5 Aug 17th, 2006 4:16 pm
