Problem shifting out of neutral to first - BMW Luxury Touring Community
post #1 of 17 Old Mar 11th, 2010, 8:19 pm Thread Starter
South Carolina Newbie. Just got a 2002 K1200LT with 15,000 miles. Great condition except from time to time I'm having a problem shifting out of neutral into first gear. Generally I have to try to shift up to second and then down. But sometimes it won't go back to first until I start moving in second. Sometimes I have a problem even getting into second from neutral until several tries later. After I'm running no problem shifting up/down, but if I stop at a light and put into neutral it's a roll of the dice as to whether or not I can get into first without doing the above. Any thoughts. Once again I'm a newbie with a BMW so I apologize for my ignorance.
c_ford is offline
post #2 of 17 Old Mar 11th, 2010, 8:33 pm
Re: Problem shifting out of neutral to first
The most likely reason is due to the dry clutch used by BMW. Unlike wet clutches that have some drag due to the viscosity of the oil between the plates, a dry clutch tends to disengage completely. The slight drag of the wet clutch allows the transmission input shaft to rotate slowly which facilitates shifting into gear. With a dry clutch, if the engagement dogs are lined up in a "blocking" arrangement, the transmission won't go into gear. There are a couple of solutions, but I favor the first:
1. Hold light pressure on the gear shift downward and then SLOWLY engage the clutch. As soon as the clutch begins to drag a little, the input shaft will begin to rotate and the dogs will engage and you are in gear and ready to go. I generally then disengage the clutch to make sure the gears are fully engaged and then move out.
2. Leave the tranny in neutral and engage and quickly disengage the clutch. Quickly shift into first. This technique gets the input shaft rotating and then you shift into gear while it is "coasting down." Depending on how fast the shaft is still rotating when the gears engage, you can get a mild clunk or a hefty clunk.
I prefer optoin one as I believe it is easier on the tranny and faster once you get the hang of it.
post #3 of 17 Old Mar 11th, 2010, 8:34 pm
shoswell's Avatar
+1
Also, check and re-lube your shift linkage.........
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #4 of 17 Old Mar 11th, 2010, 8:49 pm
Enjoy The Ride
saddleman's Avatar
Hold the clutch lever in & put slight down pressure on the shifter. Then slowly let the clutch lever out & stop when it goes in gear. Then pull the clutch lever back in. DO NOT FORCE IT INTO GEAR or the shift linkage could fail.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #5 of 17 Old Mar 11th, 2010, 9:43 pm
Originally Posted by Voyager
1. Hold light pressure on the gear shift downward and then SLOWLY engage the clutch.....
Exactly! Standard procedure - I never even gave it a thought.
Then again, I grew up on manual transmission cars with straight-cut gears, no synchro in first, so that the release-clutch-a-bit technique is natural.
Robert in Northern NJ
rdwalker is offline
post #6 of 17 Old Mar 11th, 2010, 9:52 pm
mwnahas's Avatar
Its normal, we've all found ways around it.
Move the bike back and forth so you look like a nubie try, try again.
or
if it didn't go release the clutch about half way and pull it back in again and it will usually go not as obvious as the above.
or
do the clutch slip in the previous messages.
Just Go
Cleveland Ohio
mwnahas is offline
post #7 of 17 Old Mar 12th, 2010, 4:49 am Thread Starter
Thanks so much I.
c_ford is offline
post #8 of 17 Old Mar 12th, 2010, 8:05 am
simon's Avatar
"they all do it" as they say, yes they do, you'll find your own way to deal with it and it'll become second nature to you very quickly.
I took my bike for the MOT test last week. The tester got on it, started it but couldn't get it into gear. While he was sitting on it I tried but couldn't do it either. As soon as he got off for me to try I did the "clutch half out" thing without even realsing it! I'd just accepted doing it as a matter of coures... (mind you, I have had six of these things now....I love 'em)
Simon
2006 k1200LT........my 13th!
simon is offline
post #9 of 17 Old Mar 12th, 2010, 9:55 am
Even staight cut gears with no synchro's is easier (some what) than four widely spaced "dogs" in the BWM tranny. In fact most all bikes have same constant gear mesh/dog select design. They are a bit easier as they have a wet clutch that provides a rotational force input even when disengaged. It is the dry clutch that makes this technique nessesary in the BMW. If the parts are moving they can't always line up.
post #10 of 17 Old Mar 12th, 2010, 2:10 pm Thread Starter
I tried the half clutch. Works great! Sorry for bothering you guys, but everybody's got to learn sometime even after riding 40 plus years of HD and japanese bikes, it just that this is the first dry clutch I've had.
c_ford is offline
post #11 of 17 Old Mar 22nd, 2010, 12:43 pm
pburhoe's Avatar
After I back out of my garage, I sometimes have trouble shifting into first. "Double clutching" seems to do the trick for me, I think it is a variation of what has been described above. (I pull in the clutch lever, step on the shifter...nothing. So I let the clutch out, then pull in again, she goes into gear with no problem.)
On another note, I just changed the clutch fluid and lubed the linkages...AWESOME! Shifting seems less clunky, almost "silky"...ok, I know I won't get away with that on this board...but seriously, what an improvement. I ride an '02 with 21k miles. At this rate, I will be upgrading the throttle cables soon...
Best of luck!
Peter
2002 K1200LTE (July 4, 2008)-"Dragonfly"
1984 Goldwing Aspencade-"The Mighty Pickle" (think of Arlo Guthrie)
1982 Yamaha Maxim 750-"Little Pickle" (sometimes "Gherkin")
1980 Honda 750 Four-utilitarian, classic
1978 Honda 450 Four-took it apart, couldn't put it back together...
1976 Suzuki GT 250-2 stroke screamer
pburhoe is offline
post #12 of 17 Old Mar 22nd, 2010, 12:57 pm
zippy_gg's Avatar
Exclamation Re: Problem shifting out of neutral to first
I won't discuss the difficulty shifting into first gear, instead I will comment on the fact that you seem to shift to neutral at traffic lights. That leaves you vulnerable to fumbling with shifting into first gear when the light turns green (best case scenario) and also to being rear-ended by impatient or distracted drivers (worst case scenario). Best practice is to remain in first gear, left foot on the ground and right foot on the peg, eyes peeled to the mirrors, ready to roll if/when needed. It's just me and YMMV.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #13 of 17 Old Mar 22nd, 2010, 4:40 pm
PMitchell's Avatar
I'd better check the calendar. Is it April 1st yet?
pm
Ride till you can't!
"Der Weg ist das Ziel"
2006 Tuscany
2008
2011 South Africa
'18 R1200RTW
Sold in '67
PMitchell is offline
post #14 of 17 Old Mar 22nd, 2010, 9:05 pm
zippy_gg's Avatar
Huh... the clutch is hydraulic, and the fluid does need to be replaced - along with the brake fluid - on a regular basis.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #15 of 17 Old Aug 28th, 2011, 6:00 am
Also a newbie. Just bought a 2002 K1200RS, only has 8,000 Oahu miles, but I thought something was kinda hinky with the clutch...until I found this forum. Thanks folks. I'd been adjusting, but this sounds like it's to be expected and can be worked through with some ease.
Cheers.
StreetPhilosopher is offline
post #16 of 17 Old Aug 28th, 2011, 12:24 pm
Razmataz's Avatar
Cheers.
Welcome aboard Nick. This is a great place to be for a BMW rider. Can you really get that thing in high gear in Hawaii?
BMW 1200 LTC 2002
Razmataz is offline
post #17 of 17 Old Aug 28th, 2011, 9:22 pm
Thanks, and hah! In all seriousness, I've put it into 6th on the H1, but not for very long. I'm still feeling it out and getting used to matching the rpm's and the mph's, so I was probably in 6th at 70mph a little prematurely, but I'm learning.
I'm actually really glad to have found this site. The community seems pretty solid and welcoming, and honestly just reading over the faq's as well as the forum q&a's have been immensely helpful. After some minor paranoia I'm feeling pretty good about it.
By any chance, what's a good manual to get besides the factory manual to help with regular service that I might do myself?
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 12:30 pm
Is the K1200LT a hard shifting bike ? Petre K1200LT 35 Jun 10th, 2016 11:17 am
Intaride RP-1 and cell phone problem bowlesj Intercom, CB, & 2-Way Radios 0 Nov 7th, 2007 9:15 pm
Motolight problem lnowell Lighting 4 Sep 18th, 2007 11:14 am
Mechanical Problem After a Ride hschisler K1200LT 44 Mar 26th, 2006 8:59 am
