Difficulty accessing rear tire valve - BMW Luxury Touring Community
post #1 of 3 Old Feb 24th, 2010, 8:53 am Thread Starter
Not sure if you have this issue also. But, I find it difficult, mostly with the rear wheel, to fill the tire with air. The back tire air valve can be a little difficult to access.
Any suggestions?
Does anyone know of a 90 degree air chuck?
I have seen extension valves, but I do not want to throw off the balance of the wheel.
ehaughn is offline
post #2 of 3 Old Feb 24th, 2010, 9:45 am
Re: Difficulty accessing rear tire valve
Ed, check this out. I had a similar complaint and rigged this up.
http://www.bmwlt.com/forums/showthre...e+valve+degree
It is easy to screw on and is a breeze to fill. I added a Smarttire system and now I know as soon as I start to roll my air pressures...
post #3 of 3 Old Feb 24th, 2010, 11:04 am Thread Starter
Thanks Dan, this is very helpful.
ehaughn is offline
Rear Valve Stem Failure cburton3 Tires 18 Nov 24th, 2010 9:49 pm
Rear tire let go doing 80mph..... hip001 K1200LT 43 Feb 2nd, 2009 12:14 pm
Tire Angel in Jasper BC Bob_Diachuk K1200LT 8 Jul 6th, 2008 8:48 am
Bridgestone BT020R 160/70R-17 tire failure. mudman Tires 23 Aug 28th, 2006 3:36 am
