Brake calipers - BMW Luxury Touring Community
post #1 of 16 Old Feb 21st, 2010, 1:20 pm Thread Starter
Brianmered's Avatar
Brake calipers
Can anyone tell me if Brembo calipers are available for a 2007 LT. I am having some issues with the BMW calipers as fitted and would appreciate any info.....thx
Brianmered is offline
post #2 of 16 Old Feb 21st, 2010, 1:25 pm
bikesnumbnuts's Avatar
Re: Brake calipers
Whats the problem with the bmw calipers .
regards numbnuts .
bikesnumbnuts is offline
post #3 of 16 Old Feb 21st, 2010, 3:24 pm
shoswell's Avatar
Re: Brake calipers
If you are speaking to the "Brembo" that is embossed on earlier models, yes. Because they are the same thing, they just changed the branding to BMW on the newer bikes.... If you are asking if Brembo makes an aftermarket replacement for the calipers they made for BMW, most likely not as BMW pretty much had their outside vendors swear not to make parts that were available outside of the stealer. As an example J&M made the BC3 comsystem for BMW available on the 03 and older bikes (I think) not until recently were they able to sell parts themselves...
As if we didn't know that BMW is "elitist" enough. They corner the market on BMW OEM parts as well...
Hoss
'05- K1200LT - Gretchen
MOA, IBA, EXR & RCB and TMI
shoswell is offline
post #4 of 16 Old Feb 21st, 2010, 4:49 pm
Re: Brake calipers
I believe Brembo makes all the brakes for BMW even the ones marked "BMW".
If you want to use an older style caliper they will not fit the fork legs. You will have to change out to pre- 10/2000 fork legs.
post #5 of 16 Old Feb 21st, 2010, 5:14 pm
Enjoy The Ride
saddleman's Avatar
Re: Brake calipers
You will also have to change the front wheel,rotors & ABS sensor.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #6 of 16 Old Feb 21st, 2010, 5:50 pm
LAF
LAF's Avatar
Re: Brake calipers
I cant speak for all but I am curious, what is wrong as fitted?
A description of issue/issues may lead to a pretty quick solution around here
Come on share................
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #7 of 16 Old Feb 21st, 2010, 9:49 pm Thread Starter
Brianmered's Avatar
Re: Brake calipers
Thx to those that replied....without being too long winded I am presently negotiating the purchase of a 2007 LT from a private seller. The bike only has 4000 Km on the clock which means it's been standing idle way too long ( rich boy and his toy). I test rode it and the braking was suspect, pulling sideways at slow speed. On checking the front discs the left side disc appeared not to have been braking, (not shiny) which leads me to suspect frozen caliper piston/pistons. My 2000 LT ( just sold it ) has Brembo marked calipers and I thought if I have to change the calipers (both left and right) then I would like to fit Brembo's.
Please bear with my inexperience as I read from the above that Brembo supply the BMW marked calipers.
My dilemma is should I change both front and rear calipers? If one froze what condition may the others be in or will riding it regularly keep the brakes in good shape? Are they serviceable or is changing the best option?
thanks again to those taking the time to reply....Brian
post #8 of 16 Old Feb 21st, 2010, 10:17 pm
shoswell's Avatar
Re: Brake calipers
Ask and ye shall recieve, mate!
http://www.bmwlt.com/forums/showthread.php?t=50852
Hoss
shoswell is offline
post #9 of 16 Old Feb 22nd, 2010, 9:12 am
deanwoolsey's Avatar
Re: Brake calipers
Looking to enlarge my knowledge on this one. Can someone tell me if (actually why) a failing caliper on a dual caliper wheel could cause the bike to pull to one side? It doesn't make sense to me.
deanwoolsey is offline
post #10 of 16 Old Feb 22nd, 2010, 9:25 am
Re: Brake calipers
Originally Posted by deanwoolsey
... Can someone tell me if (actually why) a failing caliper on a dual caliper wheel could cause the bike to pull to one side? ...
I give up. Can't figure why that would happen. There is no sideways momentum applied to the tire contact patch- unlike in a 4-wheeled vehicle.
After all, there are bikes with only one disc brake up front (my old KLR's come to mind) - and they do run straight.
Or, is it a hypothetical question?
Robert in Northern NJ
rdwalker is offline
post #11 of 16 Old Feb 22nd, 2010, 11:30 am
Re: Brake calipers
The OP said the bike in question pulled left at low speeds which made no sense to me. There might be another issue he needs to look at.
post #12 of 16 Old Feb 22nd, 2010, 12:59 pm Thread Starter
Brianmered's Avatar
Re: Brake calipers
I'm fast slipping into unknown territory here....the bike felt as if it pulled to the right at slow speeds down a slight incline into my basement parking. Upon examination the left caliper appeared not to have worked as hard as the right caliper, however I'm now suspecting the tyres may also be a contributing factor. Upon close examination and after removing the tyre black that someone has applied I can see fine side wall cracks in both tyres which suggest the tyres have started to harden and lose their suppleness. Checked the date and they were manufactured 10/06.
In the Middle East with very high summer temperatures and high UV levels the tyres, if unused for any length of time, deteriorate at a much faster rate than would be expected in more temperate zones. This machine has done less then 4000 Kms in 3 years. I'm therefore planning to ask the dealer to change the tyres (they are not selling the bike and appear reluctant to offer opinions) and then take it for another test ride. Both front calipers have now been removed ( by the dealer) and the piston movement confirmed on both. It's highly likely that my test ride started to free them up and with more constant use should not become an issue again.
I'm unsure what else to look for, any suggestions welcomed....
post #13 of 16 Old Feb 22nd, 2010, 1:14 pm
zippy_gg's Avatar
Re: Brake calipers
IIRC the early calipers were from Brembo, but not the later ones. Tokico or some other Japanese name... can't recall for sure.
Also when was the last time the brake fluid was changed?
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #14 of 16 Old Feb 22nd, 2010, 2:56 pm
shoswell's Avatar
Re: Brake calipers
Updated my post link in #8 to include the original pictures....Sorry 'bout that.
Hoss
shoswell is offline
post #15 of 16 Old Feb 23rd, 2010, 12:23 pm Thread Starter
Brianmered's Avatar
Talking Re: Brake calipers
Thx everyone, the deal is done, proud owner of a 'new' low mileage LT. Changed the tyres and confirmed the pistons are now free in the front calipers, what a difference! The bike goes where I point it and pulls up smooth at whatever speed I'm travelling.
from one happy guy........
post #16 of 16 Old Feb 23rd, 2010, 1:01 pm
Steve_R's Avatar
Re: Brake calipers
I love it when a story has a happy ending.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
Speed Bleeders and DOT 5 atrovarious K1200LT 11 Jun 24th, 2010 10:27 pm
Pulled the plug-- MN.GT K1200/1300GT (The Next Generation) 37 Mar 4th, 2009 7:49 pm
Torque setting on brake calipers ?? BToliver K1200LT 11 Sep 9th, 2006 7:11 am
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 11:48 pm
