LT Won't Start - BMW Luxury Touring Community
post #1 of 8 Old Feb 13th, 2010, 11:20 am Thread Starter
rattler50's Avatar
Unhappy LT Won't Start
The other day I shorted out my PIAA lights at the switch when in came apart. I got a new switch and went out to replace it. Bike has been parked for a couple of weeks due to bad weather and snow. I found a 4Amp fuse blown and swapped out the fuse from the heated grips. I tried to start it and I hear all the usual noises but just a small "click" when I hit the starter. Battery seemed to be low because shortly after trying this a few times everything kinda went crazy and got dimmer on the dash. Reckon my battery is gone? It's a gel battery installed in 06. I didn't have the battery tender hooked up. Any ideas?.........
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #2 of 8 Old Feb 13th, 2010, 11:34 am
LAF
LAF's Avatar
Re: LT Won't Start
You could measure your battery voltage but I suspect it is very low. I would put the tender on it and see it it comes up.
Trying to start on a low battery can cause serious issues. Stuck relays to start and they are no fun to get to and buy. I would charge it and try another day to start it.
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #3 of 8 Old Feb 13th, 2010, 11:38 am Thread Starter
rattler50's Avatar
Re: LT Won't Start
Thanks. I was gonna do a ride with a friend. The ground here is covered in snow but the roads are clear. I shoveled a path to the road. Oh, well. Another day. Where can I find a fuse to replace the one that blew? Are they standard blade type fuses? Thanks again..............
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #4 of 8 Old Feb 13th, 2010, 11:44 am
Re: LT Won't Start
Since your bike is a 2003, you do not have to worry about the old stuck relay problem, as the change to the new protected relay happened sometime in 2001 model year if I remember correctly. With that newer circuit, the starter relay is disabled when the battery voltage is too low.
Charge or replace the battery and you should be OK to go again.
post #5 of 8 Old Feb 13th, 2010, 11:54 am Thread Starter
rattler50's Avatar
Re: LT Won't Start
I took my volt meter and checked my pickup battery. I then checked my motorcycle battery. The volts were about the same. I wiggled the shifter and then hit the starter. It turned over slowly so I let it go. I either need a new battery or a good charge on this one. Thanks again.....................
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #6 of 8 Old Feb 13th, 2010, 7:59 pm Thread Starter
rattler50's Avatar
Re: LT Won't Start
Just for the heck of it I hit the starter. It busted right off. I took a little 175 mile ride with some friends. Working great now....................
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #7 of 8 Old Feb 14th, 2010, 7:30 am
LAF
LAF's Avatar
Re: LT Won't Start
Good stuff.
I still would keep the battery tended for a bit. Also check the voltage with the battery at rest, meaning remove the charger for 24 hours then measure the voltage.
I wish I could get out for a ride
Lee
BMW MOA #135959
LAF is offline
post #8 of 8 Old Feb 14th, 2010, 7:39 am
wacolt's Avatar
Re: LT Won't Start
I'm glad you got it running again; I was out yesterday on the Duc. A beautiful sunny day for a ride.
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
Ignition or fuel problem, No start ridinredfox K1200LT 26 Jan 14th, 2010 9:15 am
Difficult start after refueling Schweintechnik K1200LT 19 Jul 21st, 2009 10:01 pm
2003 LT a No Start Problem knlkern K1200LT 11 Aug 26th, 2008 10:00 pm
Darn thing wont start - any ideas? TWheels K1200LT 17 May 16th, 2007 11:35 am
