Brake Bleeding Sequence - BMW Luxury Touring Community
post #1 of 8 Old Feb 6th, 2010, 1:32 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
I am installing new Speigler brake lines. I'm thinking that I should bleed the ABS system first & then do the power bleed on the calipers.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #2 of 8 Old Feb 6th, 2010, 3:50 pm
Re: Brake Bleeding Sequence
"yupp"
post #3 of 8 Old Feb 6th, 2010, 4:10 pm
Yes Dave, key off bleed the control circuits until the lever and pedal are firm. Then re-fill the rear two chambered reservoir and run some "powered " fluid through to the wheel circuits. Kind of neat to run a hose from the bleeder back to the reservoir and pump until the bubbles are gone in the hose.
post #4 of 8 Old Feb 6th, 2010, 5:28 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
Thanks guys: I just finished & ran a quart of new dot 4 thru the system. No leaks & the pedal & hand lever feel good. I did have to bleed the calipers a little to get some pressure to finish bleeding the ABS unit. I'm now about halfway down my list of to do things on my Black Beauty.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #5 of 8 Old Feb 6th, 2010, 9:45 pm
Similar but different question: If I replace the rear brake hose on a 2000, can I just bleed through the caliper with my Mity-vac and leave the ABS alone??
hwread is offline
post #6 of 8 Old Feb 6th, 2010, 10:38 pm
Lee510's Avatar
The manual says you don't need to bleed the ABS unit unless the system has been drained. Removing the brake line may cause the level in the ABS unit to drop. For my own piece of mind, I'd push some out of the rear nipple. Maybe even the front, while I was doing it. Our ABS units sometime fail and I think it's due to not getting the old fluid out of the ABS unit when flushing the system. I read here somewhere that flushing from reservior to caliper moves fluid but may not move it all out of the ABS unit.
Lee
2005 K1200 LT Ocean Blue
ATGATT
CCR 2009, CCR 2010, CCR 2012
IBA #39250
SS1000 - September 2009
BB1500 - September 2009
BMW MOA #167909
Lee510 is offline
post #7 of 8 Old Feb 7th, 2010, 8:05 am
I'm not worried about getting the ABS flushed as it was done less than a year ago. All I'm after is Improving the nearly useless rear brake. Think I'll give it a try.
hwread is offline
post #8 of 8 Old Feb 7th, 2010, 12:06 pm
The early ABS bleed ports are just a high point bleed area. No need to touch them during a flush but I would if the rear line was off. They are at the top of a small chamber that gets modulated in volume by an electromechanical piston during ABS activation. I say again small chamber but if it has air in it your rear brakes will suffer in performance. All the fluid from the reservoir goes through the ABS and out the rear caliper bleed port.This is quite different from the later linked and power assisted ABS.
Brake System Bleeding old1951 K1200LT 6 Aug 12th, 2009 8:10 am
Brake Bleeding Fatality AlReich23 K1200LT 13 Sep 30th, 2008 9:15 am
Rear brake dragging '00, bleeding abs? waynelt K1200LT 2 Aug 6th, 2007 3:12 pm
Need some help with brake bleeding scott122262 K1200LT 13 Mar 20th, 2006 10:04 pm
New Article Posted - Brake Bleeding eljeffe K1200LT 1 Oct 19th, 2005 12:18 pm
